[postgis-users] shp2pgsql problem with Leopard
Paul Ramsey
pramsey at refractions.net
Sat Feb 9 16:50:57 PST 2008
I re-named and found things began working... I am hesitant to commit
my patch though, since I know SFA about C at this point. In
particular, what bits to rename in getopt.h were not clear to me, so I
renamed every *getopt function, which may have been overkill.
P
On Dec 30, 2007, at 10:44 AM, William Kyngesburye wrote:
> On Dec 30, 2007, at 12:16 PM, William Kyngesburye wrote:
>> If the two different declarations of getopt are causing the
>> problem, I wonder if Apple's getopt will work (it's BSD getopt)?
>> Or did you customize getopt for postgis?
> Well, Apple's BSD getopt works in 64bit mode, but not 32bit mode.
> This time it seems to be not getting the options correctly, and I
> get an error that:
> shape (.shp) or index files (.shx) can not be opened.
> So Apple's getopt is not a usable alternative. This may be another
> case of needing to rename it (like the earlier get_uint32 problem).
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "I ache, therefore I am. Or in my case - I am, therefore I ache."
> - Marvin
> postgis-users mailing list
