[postgis-users] Adding a new GEOS call to PostGIS
Dylan Beaudette dylan.beaudette at gmail.com
Tue Feb 12 10:30:52 PST 2008
On Tuesday 12 February 2008, Paul Ramsey wrote:
> OK, it was a bit harder than you interpreted (takes more than a SQL
> cut'n'paste) and not as straightforward as I thought it might be (the
> simplify function that was already there was a native implementation,
> not a GEOS call, so cutting and pasting it would do no good).
> Anyhow, I have applied my incredible text editing skills and now there
> is a ST_SimplifyPreserveTopology(geometry, float) in the -svn drop.
> Paul
Nice work Paul-
Am I correct in understanding that the ST_SimplifyPreserveTopology() function
would give topologically correct polygons after simplification? In other
words, it would preserve adjacency after simplification?
I have noticed that running simplify() on a set of adjacent polygons sometimes
has the not-so-nice result of causing previously overlapping (dang simple
features!) edges to separate.
Dylan
> On Feb 8, 2008, at 10:21 PM, Brian Hamlin wrote:
> > It recently came up in the IRC channel FreeNode #postgis
> > that there is a GEOS TopologyPreserveSimplify, in addition
> > to Simplify2D.
> > I did a bit of checking just now.. on my machine, I see
> > nm /usr/local/pgsql/lib/liblwgeom.1.3.so
> > _LWGEOM_simplify2d
> > _pg_finfo_LWGEOM_simplify2d
> > _simplify2d_lwgeom
> >   and some others, but no TopologyPreserve anything
> > nm /usr/lcoal/lib/libgeos_c.1.4.1.dylib
> > _GEOSSimplify
> > _GEOSTopologyPreserveSimplify
> > and lastly, in lwpostgis.sql
> >  CREATE OR REPLACE FUNCTION simplify(geometry, float8)
> >    RETURNS geometry
> >    AS '$libdir/liblwgeom', 'LWGEOM_simplify2d'
> >    LANGUAGE 'C' IMMUTABLE STRICT;
> > since the last SQL line matches the exported symbol name from
> > liblwgeom
> > exactly, minus the front _, looks like there is the exact entry point.
> > Clearly no parallel entry for TopologyPreseveSimplify
> > this makes me think that there is a little more to adding the call to
> > lwpostgis.sql than copying and pasting the declaration.
> > insights welcome
> >   -Brian
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
Dylan Beaudette
Soil Resource Laboratory
http://casoilresource.lawr.ucdavis.edu/
University of California at Davis
530.754.7341
