[postgis-users] Adding a new GEOS call to PostGIS
Paul Ramsey pramsey at refractions.net
Tue Feb 12 11:01:16 PST 2008
On 12-Feb-08, at 10:30 AM, Dylan Beaudette wrote:
> Am I correct in understanding that the ST_SimplifyPreserveTopology
> () function
> would give topologically correct polygons after simplification? In
> other
> words, it would preserve adjacency after simplification?
No, incorrect, perhaps this calls for a renaming. It will preserve
validity, that is, each individual polygon will remain topologically
correct.
> I have noticed that running simplify() on a set of adjacent
> polygons sometimes
> has the not-so-nice result of causing previously overlapping (dang
> simple
> features!) edges to separate.
Sorry, that remains a hard problem to crack. I doubt anything short
of a build-coverage/simplify-edges/extract-polygons approach is going
to do it.
P.
> Dylan
>> On Feb 8, 2008, at 10:21 PM, Brian Hamlin wrote:
>>> It recently came up in the IRC channel FreeNode #postgis
>>> that there is a GEOS TopologyPreserveSimplify, in addition
>>> to Simplify2D.
>>> I did a bit of checking just now.. on my machine, I see
>>> nm /usr/local/pgsql/lib/liblwgeom.1.3.so
>>> _LWGEOM_simplify2d
>>> _pg_finfo_LWGEOM_simplify2d
>>> _simplify2d_lwgeom
>>>   and some others, but no TopologyPreserve anything
>>> nm /usr/lcoal/lib/libgeos_c.1.4.1.dylib
>>> _GEOSSimplify
>>> _GEOSTopologyPreserveSimplify
>>> and lastly, in lwpostgis.sql
>>>  CREATE OR REPLACE FUNCTION simplify(geometry, float8)
>>>    RETURNS geometry
>>>    AS '$libdir/liblwgeom', 'LWGEOM_simplify2d'
>>>    LANGUAGE 'C' IMMUTABLE STRICT;
>>> since the last SQL line matches the exported symbol name from
>>> liblwgeom
>>> exactly, minus the front _, looks like there is the exact entry
>>> point.
>>> Clearly no parallel entry for TopologyPreseveSimplify
>>> this makes me think that there is a little more to adding the
>>> call to
>>> lwpostgis.sql than copying and pasting the declaration.
>>> insights welcome
>>>   -Brian
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> Dylan Beaudette
> Soil Resource Laboratory
> http://casoilresource.lawr.ucdavis.edu/
> University of California at Davis
> 530.754.7341
