[postgis-users] Validating geometry with trigger function
Johannes Sommer
johann.online at gmx.de
Tue Feb 12 12:17:43 PST 2008
Hi again,
I solved my problem. :-)
The point is that the subquery
"SELECT st_within(NEW.geometry, a.geometry) FROM Area1 a WHERE a.fl_id =
NEW.fl_fk"
returns a boolean as 't' or 'f' and not as 0 or 1.
It works with the following:
CREATE OR REPLACE FUNCTION check_geom()
RETURNS "trigger" AS
$BODY$
BEGIN
IF (SELECT st_within(NEW.geometry, a.geometry) FROM Area1 a WHERE
a.fl_id = NEW.fl_fk) = 'f' THEN
RAISE EXCEPTION 'Geometry is not valid!';
RETURN NULL;
ELSE
RETURN NEW;
END IF;
END;
$BODY$
LANGUAGE 'plpgsql' VOLATILE;
ALTER FUNCTION check_geom() OWNER TO postgres;
bye,
Johannes
Johannes Sommer schrieb:
> Hi all,
> I'm facing the following problem:
> Area1 has got an 1:n relationship to Area2.
> Area1, fl_id (PK) <----- Area2, fl_fk (FK)
> 1 : n
> Now I want to ensure that this relationship will also be spatially.
> I only want to have new geometry objects in table Area2, which are
> within Area1 including the 1:n relationship.
> (if that sounds bad, sorry for my poor english ;-)).
> Example: Area2, fl_fk = 1 must be within Area1, fl_id = 1
> | Area1, fl_id = 1 |
> | | Area2, | |
> | | fl_fk = 1 | |
> The following trigger won't work.
> $BODY$
> BEGIN
> a.fl_id = NEW.fl_fk) <> 1 THEN
> RETURN NEW;
> END IF;
> END;
> $BODY$
> CREATE TRIGGER trig_check_geom
> BEFORE INSERT OR UPDATE
> ON Area2
> FOR EACH ROW
> EXECUTE PROCEDURE check_geom();
> Everytime I insert a geometry object into table Area2, regardless
> wether it's within an polygon of Area1 or not, I get the exception.
> Any help would be appreciated.
> bye,
> Johannes
> postgis-users mailing list
