[postgis-users] Re: postgis-users Digest, Vol 64, Issue 13
Paul Ramsey pramsey at refractions.net
Wed Feb 13 15:55:29 PST 2008
Hmm...
These layers have entries in geometry_columns ?
The SRIDs these layers reference in geometry_columns are in
spatial_ref_sys?
The SRIDs these layers have in geometry_columns match the SRIDs in the
geometries themselves (select distinct st_srid(geom) from thetable)?
The SRIDs these layers have accurately describe the projection system
they are in? Can you back project into lat/lon correctly? (select
st_transform(geom, 4326) from thetable)
P
On Feb 13, 2008, at 3:40 PM, Richard Heimann [C] wrote:
> Hello All,
> I am experiencing some strange behavior with PostGIS and
> Udig...behavior
> that has certainly been handled before (I suspect) but I could find no
> mention of it on the mailing lists.
> After connecting to my PostgreSQL Db(8.2) with PostGIS (1.3.1) via
> Udig(1.1 RC11) I get some of my dataset showing their proper geometry
> while others with a generic block symbol. These layers (with the
> generic
> block) will not load into Udig, I receive an exception "targetCRS
> should
> not be null."
> Ive checked the table and it most certainly has the appropriate
> branding,
> moreover all the derived tables appear correctly. In fact, I can
> create a
> table using a select * and that table appears correctly.
> Any suggestions. I also vacumed the table and recalibrated its
> statistics.
> Thoughts?
> Regards
> Richard
> postgis-users mailing list
