[postgis-users] Re: [postgis-devel] Proposal for supporting Extrude, Tesselate, and Altitudemode options in PostGIS KML generator
Paul Ramsey
pramsey at refractions.net
Mon Feb 18 12:47:32 PST 2008
I hope others are testing this out...
I have some aesthetic concerns with how you are passing arguments, I
wonder if there is a more elegant way do to it. I feel like
requiring a precision argument in order to do the other options would
be preferable to the "size of precision" hack to distinguish between
options and precision. Others may disagree.
P.
On 14-Feb-08, at 11:01 AM, Eduin Carrillo wrote:
> Add the possibility to customize KML code produced by PostGIS with
> altitude mode (altitudeMode), allow lines and paths to follow the
> terrain (tessellate), and how to connect primitive to the ground
> (extrude).
> http://code.google.com/p/postexperiments/wiki/
> Extrude_Tesselate_and_Altitudemode_Support
> http://code.google.com/p/postexperiments/issues/detail?id=1
