RE: [postgis-users] Re: [postgis-devel] Proposal for supporting Extrude, Tessel
guido.lemoine at jrc.it guido.lemoine at jrc.it
Wed Feb 20 23:20:34 PST 2008
In effect, this issue is about styling of KML, and not so
much about the real data itself. I wonder whether postgis
should be concerned with that too much.
askml() produces only partial KML fragments anyway, so you
always have to make an effort, external to postgis, to
produce valid KML for display in GE (e.g. using XSLT).
This may as well include styling.
I'm not suggesting this is not a good idea, but IMHO, it's
not essential.
GL
>-- Original Message --
>From: Dane Springmeyer <blake at hailmail.net>
>To: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
>Date: Tue, 19 Feb 2008 09:45:14 -0800
>Subject: [postgis-users]
>	Re: [postgis-devel] Proposal for supporting Extrude, Tesselate,
>	and Altitudemode options in PostGIS KML generator
>Reply-To: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
>As far as the KML proposal and syntax, I think both Paul and Martin's
>suggestions are good improvements.
>> What about providing a string parameter which can supply the various
>> options in a human-readable format?
>> E.g. "extrude=1 tesselate=0 altitudeMode=clampToGround"
>> Easy to read, easy to parse, easy to extend...
>If I had to choose between them I think the ease of reading of this
>approach above is the nicest, if not most grass=like.
>Thanks so much to Eduin for pulling this together.
>Anyone have more thoughts?
>Cheers,
>Dane
>_______________________________________________
>postgis-users mailing list
>http://postgis.refractions.net/mailman/listinfo/postgis-users
