[postgis-users] Re: [mapserver-users] can an ogr tileindex refer to a PG table?
Paul Ramsey
pramsey at cleverelephant.ca
Wed Feb 27 11:32:42 PST 2008
Are you confirming that still doesn't work? What I make of it is that
the interaction of the SQL parser, the planner and the constraint
exclusion code might not allow your sub-select trick, but you should
seek the advice of experts on the pgsql list.
P.
On 2/27/08, Neil Best <nbest at lanworth.com> wrote:
> Paul Ramsey wrote:
> > What happens when you remove PostGIS from the equation. This might be
> > a core PgSQL question.
> > EXPLAIN ANALYZE SELECT count(*) FROM mapunits
> > WHERE areasymbol IN (SELECT 'IA199' as a)
> I think you're on to something there, Paul. Very astute. What do you
> make of this?
