[postgis-users] Re: [mapserver-users] can an ogr tileindex refer to a PG table?
Neil Best
nbest at lanworth.com
Wed Feb 27 12:05:55 PST 2008
Paul Ramsey wrote:
> Are you confirming that still doesn't work? What I make of it is that
> the interaction of the SQL parser, the planner and the constraint
> exclusion code might not allow your sub-select trick, but you should
> seek the advice of experts on the pgsql list.
Precisely. I will either pursue that advice or settle for the
work-around of issuing the sub-query separately and stuffing the results
back into a subsequent query. Not very satisfactory on the elegance
front but high coefficient of laziness. Thanks, Paul.
