[postgis-users] PostgreSQL / PostGIS Issue - SQL state: 42883
Darrell Sher
darrell.sher at roost.com
Wed Jan 2 21:49:20 PST 2008
Issue:
When I run the lwpostgis.sql script it fails when creating the
histogram2d type with the error:
ERROR: function st_histogram2d_out(histogram2d) does not exist
SQL state: 42883
I can create the associated functions for the histogram2d type by hand,
but I still get the same message when creating the type.
I can however, successfully create the spheroid functions & types from
the lwpostgis.sql script by hand.
Any ideas where I should look for what is failing.
Background:
System: Red Hat ES v5 64-bit
-bash-3.1$ uname -a
Linux oc-db01.roost.local 2.6.18-53.el5 #1 SMP Wed Oct 10 16:34:19 EDT
2007 x86_64 x86_64 x86_64 GNU/Linux
PostgreSQL:
-bash-3.1$ pg_config
BINDIR = /usr/bin
DOCDIR = /usr/share/doc/pgsql
INCLUDEDIR = /usr/include
PKGINCLUDEDIR = /usr/include/pgsql
INCLUDEDIR-SERVER = /usr/include/pgsql/server
LIBDIR = /usr/lib64
PKGLIBDIR = /usr/lib64/pgsql
LOCALEDIR = /usr/share/locale
MANDIR = /usr/share/man
SHAREDIR = /usr/share/pgsql
SYSCONFDIR = /etc/sysconfig/pgsql
PGXS = /usr/lib64/pgsql/pgxs/src/makefiles/pgxs.mk
CONFIGURE = '--build=x86_64-redhat-linux-gnu'
'--host=x86_64-redhat-linux-gnu' '--target=x86_64-redhat-linux-gnu'
'--program-prefix=' '--prefix=/usr' '--exec-prefix=/usr'
'--bindir=/usr/bin' '--sbindir=/usr/sbin' '--sysconfdir=/etc'
'--datadir=/usr/share' '--includedir=/usr/include' '--libdir=/usr/lib64'
'--libexecdir=/usr/libexec' '--localstatedir=/var'
'--sharedstatedir=/usr/com' '--mandir=/usr/share/man'
'--infodir=/usr/share/info' '--disable-rpath' '--with-perl'
'--with-python' '--with-tcl' '--with-tclconfig=/usr/lib64'
'--with-openssl' '--with-pam' '--with-krb5'
'--with-includes=/usr/include' '--with-libraries=/usr/lib64'
'--enable-nls' '--enable-thread-safety'
'--sysconfdir=/etc/sysconfig/pgsql' '--datadir=/usr/share/pgsql'
'--with-docdir=/usr/share/doc' 'CFLAGS=-O2 -g -pipe -Wall
-Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector
--param=ssp-buffer-size=4 -m64 -mtune=generic -I/usr/include/et'
'CPPFLAGS= -I/usr/include/et' 'build_alias=x86_64-redhat-linux-gnu'
'host_alias=x86_64-redhat-linux-gnu'
'target_alias=x86_64-redhat-linux-gnu'
CC = gcc
CPPFLAGS = -D_GNU_SOURCE -I/usr/include
CFLAGS = -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions
-fstack-protector --param=ssp-buffer-size=4 -m64 -mtune=generic
-I/usr/include/et -Wall -Wmissing-prototypes -Wpointer-arith -Winline
-Wdeclaration-after-statement -Wendif-labels -fno-strict-aliasing
CFLAGS_SL = -fpic
LDFLAGS = -L/usr/lib64
LDFLAGS_SL =
LIBS = -lpgport -lpam -lssl -lcrypto -lkrb5 -lz -lreadline -ltermcap
-lcrypt -ldl -lm
VERSION = PostgreSQL 8.2.5
postgressql.conf:
dynamic_library_path = '$libdir:/usr/local/lib'
#local_preload_libraries = ''
postgres .bash_profile:
LD_LIBRARY_PATH=/usr/lib64/pgsql:/usr/local/lib:$LD_LIBRARY_PATH
export LD_LIBRARY_PATH
Geos & Proj4:
[root at oc-db01 bin]# cd /usr/local/lib
[root at oc-db01 lib]# ll
total 49984
-rwxr-xr-x 1 root root 13039412 Dec 27 11:56 libgeos-3.0.0rc4.so
-rw-r--r-- 1 root root 34289648 Dec 27 11:56 libgeos.a
-rw-r--r-- 1 root root 509840 Dec 27 11:56 libgeos_c.a
-rwxr-xr-x 1 root root 832 Dec 27 11:56 libgeos_c.la
lrwxrwxrwx 1 root root 18 Dec 27 11:56 libgeos_c.so ->
libgeos_c.so.1.3.3
lrwxrwxrwx 1 root root 18 Dec 27 11:56 libgeos_c.so.1 ->
libgeos_c.so.1.3.3
-rwxr-xr-x 1 root root 282107 Dec 27 11:56 libgeos_c.so.1.3.3
-rwxr-xr-x 1 root root 809 Dec 27 11:56 libgeos.la
lrwxrwxrwx 1 root root 19 Dec 27 11:56 libgeos.so ->
libgeos-3.0.0rc4.so
-rw-r--r-- 1 root root 2005348 Dec 27 12:00 libproj.a
-rwxr-xr-x 1 root root 796 Dec 27 12:00 libproj.la
lrwxrwxrwx 1 root root 16 Dec 27 12:00 libproj.so ->
libproj.so.0.5.2
lrwxrwxrwx 1 root root 16 Dec 27 12:00 libproj.so.0 ->
libproj.so.0.5.2
-rwxr-xr-x 1 root root 889693 Dec 27 12:00 libproj.so.0.5.2
PostGIS:
[root at oc-db01 pgsql]# ldd liblwgeom.so.1.3
libgeos_c.so.1 => /usr/local/lib/libgeos_c.so.1
(0x00002aaaaad0e000)
libproj.so.0 => /usr/local/lib/libproj.so.0 (0x00002aaaaaf1b000)
libc.so.6 => /lib64/libc.so.6 (0x00002aaaab179000)
libgeos-3.0.0rc4.so => /usr/local/lib/libgeos-3.0.0rc4.so
(0x00002aaaab4ca000)
libstdc++.so.6 => /usr/lib64/libstdc++.so.6 (0x00002aaaab80b000)
libm.so.6 => /lib64/libm.so.6 (0x00002aaaabb0b000)
libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00002aaaabd8f000)
/lib64/ld-linux-x86-64.so.2 (0x0000555555554000)
The PostGIS make config is successful.
Thank you,
Darrell
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080103/d018631d/attachment.html>
