[postgis-users] PostgreSQL / PostGIS Issue - SQL state: 42883
Paul Ramsey pramsey at refractions.net
Thu Jan 3 09:01:56 PST 2008
Darrell,
Pare down the script to just the three entries that create the _in
and _out functions and the type and send the output from that...
Seems very odd to me.
P
On 2-Jan-08, at 9:49 PM, Darrell Sher wrote:
> Issue:
> When I run the lwpostgis.sql script it fails when creating the
> histogram2d type with the error:
> ERROR: function st_histogram2d_out(histogram2d) does not exist
> SQL state: 42883
> I can create the associated functions for the histogram2d type by
> hand, but I still get the same message when creating the type.
> I can however,  successfully create the spheroid functions & types
> from the lwpostgis.sql script by hand.
> Any ideas where I should look for what is failing.
> Background:
> System: Red Hat ES v5 64-bit
> -bash-3.1$ uname -a
> Linux oc-db01.roost.local 2.6.18-53.el5 #1 SMP Wed Oct 10 16:34:19
> EDT 2007 x86_64 x86_64 x86_64 GNU/Linux
> PostgreSQL:
> -bash-3.1$ pg_config
> BINDIR = /usr/bin
> DOCDIR = /usr/share/doc/pgsql
> INCLUDEDIR = /usr/include
> PKGINCLUDEDIR = /usr/include/pgsql
> INCLUDEDIR-SERVER = /usr/include/pgsql/server
> LIBDIR = /usr/lib64
> PKGLIBDIR = /usr/lib64/pgsql
> LOCALEDIR = /usr/share/locale
> MANDIR = /usr/share/man
> SHAREDIR = /usr/share/pgsql
> SYSCONFDIR = /etc/sysconfig/pgsql
> PGXS = /usr/lib64/pgsql/pgxs/src/makefiles/pgxs.mk
> CONFIGURE = '--build=x86_64-redhat-linux-gnu' '--host=x86_64-redhat-
> linux-gnu' '--target=x86_64-redhat-linux-gnu' '--program-prefix='
> '--prefix=/usr' '--exec-prefix=/usr' '--bindir=/usr/bin' '--
> sbindir=/usr/sbin' '--sysconfdir=/etc' '--datadir=/usr/share' '--
> includedir=/usr/include' '--libdir=/usr/lib64' '--libexecdir=/usr/
> libexec' '--localstatedir=/var' '--sharedstatedir=/usr/com' '--
> mandir=/usr/share/man' '--infodir=/usr/share/info' '--disable-
> rpath' '--with-perl' '--with-python' '--with-tcl' '--with-
> tclconfig=/usr/lib64' '--with-openssl' '--with-pam' '--with-krb5'
> '--with-includes=/usr/include' '--with-libraries=/usr/lib64' '--
> enable-nls' '--enable-thread-safety' '--sysconfdir=/etc/sysconfig/
> pgsql' '--datadir=/usr/share/pgsql' '--with-docdir=/usr/share/doc'
> 'CFLAGS=-O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -
> fstack-protector --param=ssp-buffer-size=4 -m64 -mtune=generic -I/
> usr/include/et' 'CPPFLAGS= -I/usr/include/et' 'build_alias=x86_64-
> redhat-linux-gnu' 'host_alias=x86_64-redhat-linux-gnu'
> 'target_alias=x86_64-redhat-linux-gnu'
> CC = gcc
> CPPFLAGS = -D_GNU_SOURCE -I/usr/include
> CFLAGS = -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -
> usr/include/et -Wall -Wmissing-prototypes -Wpointer-arith -Winline -
> Wdeclaration-after-statement -Wendif-labels -fno-strict-aliasing
> CFLAGS_SL = -fpic
> LDFLAGS = -L/usr/lib64
> LDFLAGS_SL =
> LIBS = -lpgport -lpam -lssl -lcrypto -lkrb5 -lz -lreadline -
> ltermcap -lcrypt -ldl -lm
> VERSION = PostgreSQL 8.2.5
> postgressql.conf:
> dynamic_library_path = '$libdir:/usr/local/lib'
> #local_preload_libraries = ''
> postgres   .bash_profile:
> LD_LIBRARY_PATH=/usr/lib64/pgsql:/usr/local/lib:$LD_LIBRARY_PATH
> export LD_LIBRARY_PATH
> Geos & Proj4:
> [root at oc-db01 bin]# cd /usr/local/lib
> [root at oc-db01 lib]# ll
> total 49984
> -rwxr-xr-x 1 root root 13039412 Dec 27 11:56 libgeos-3.0.0rc4.so
> -rw-r--r-- 1 root root 34289648 Dec 27 11:56 libgeos.a
> -rw-r--r-- 1 root root   509840 Dec 27 11:56 libgeos_c.a
> -rwxr-xr-x 1 root root      832 Dec 27 11:56 libgeos_c.la
> lrwxrwxrwx 1 root root       18 Dec 27 11:56 libgeos_c.so ->
> libgeos_c.so.1.3.3
> lrwxrwxrwx 1 root root       18 Dec 27 11:56 libgeos_c.so.1 ->
> libgeos_c.so.1.3.3
> -rwxr-xr-x 1 root root   282107 Dec 27 11:56 libgeos_c.so.1.3.3
> -rwxr-xr-x 1 root root      809 Dec 27 11:56 libgeos.la
> lrwxrwxrwx 1 root root       19 Dec 27 11:56 libgeos.so ->
> libgeos-3.0.0rc4.so
> -rw-r--r-- 1 root root  2005348 Dec 27 12:00 libproj.a
> -rwxr-xr-x 1 root root      796 Dec 27 12:00 libproj.la
> lrwxrwxrwx 1 root root       16 Dec 27 12:00 libproj.so ->
> libproj.so.0.5.2
> lrwxrwxrwx 1 root root       16 Dec 27 12:00 libproj.so.0 ->
> libproj.so.0.5.2
> -rwxr-xr-x 1 root root   889693 Dec 27 12:00 libproj.so.0.5.2
> PostGIS:
> [root at oc-db01 pgsql]# ldd liblwgeom.so.1.3
>         libgeos_c.so.1 => /usr/local/lib/libgeos_c.so.1
> (0x00002aaaaad0e000)
>         libproj.so.0 => /usr/local/lib/libproj.so.0
> (0x00002aaaaaf1b000)
>         libc.so.6 => /lib64/libc.so.6 (0x00002aaaab179000)
>         libgeos-3.0.0rc4.so => /usr/local/lib/libgeos-3.0.0rc4.so
> (0x00002aaaab4ca000)
>         libstdc++.so.6 => /usr/lib64/libstdc++.so.6
> (0x00002aaaab80b000)
>         libm.so.6 => /lib64/libm.so.6 (0x00002aaaabb0b000)
>         libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00002aaaabd8f000)
>         /lib64/ld-linux-x86-64.so.2 (0x0000555555554000)
> The PostGIS make config is successful.
> Thank you,
> Darrell
> postgis-users mailing list
