[postgis-users] psql:/usr/local/pgsql/share/lwpostgis.sql:44: ERREUR: Impossible d'accéder au fichier "$libdir/liblwgeom" : No such file or directory
Sebastien ARBOGAST
sebastien.arbogast at gmail.com
Tue Jan 8 14:23:33 PST 2008
I'm trying to create a postgis template database on a postgis server I
just installed from source. I'm using postgresql-8.2.6 and
postgis-1.3.2.
But here is the log I get when I try to import lwpostgis.sql into my
template_postgis database:
$ psql -d template_postgis -f /usr/local/pgsql/share/lwpostgis.sql
BEGIN
psql:/usr/local/pgsql/share/lwpostgis.sql:44: NOTICE: Taper
«histogram2d» n'est pas encore défini
DETAIL: Création de la définition d'un shell type.
psql:/usr/local/pgsql/share/lwpostgis.sql:50: ERREUR: La transaction
courante est annulée, les commandes sont ignorées jusqu'à la fon du
bloc de la transaction
This error seems to be very frequent but I couldn't find any thread on
a forum or mailing list where a final solution is suggested.
FYI, here is the summary I get from postgis configure and liblwgeom.so
is in /usr/local/pgsql/lib
SUMMARY
HOST_OS: linux-gnu
PGSQL: /usr/local/pgsql/bin/pg_config
GEOS: /usr/local/bin/geos-config (with C-API)
(ldflags: -L/usr/local/lib)
PROJ: prefix=/usr/local libdir=/usr/local/lib
ICONV: 1
PORTNAME: linux
PREFIX: /usr/local/pgsql
EPREFIX: ${prefix}
DOC: /usr/local/pgsql/doc/contrib
DATA: ${datarootdir}
MAN: ${datarootdir}/man
BIN: /usr/local/pgsql/bin
EXT: /usr/local/pgsql/lib (\$$libdir)
Please help.
Sébastien Arbogast
http://www.sebastien-arbogast.com
