[postgis-users] psql:/usr/local/pgsql/share/lwpostgis.sql:44: ERREUR: Impossible d'accéder au fichier "$libdir/liblwgeom" : No such file or directory
Tim Bowden
tim.bowden at westnet.com.au
Tue Jan 8 17:23:53 PST 2008
On Tue, 2008-01-08 at 23:23 +0100, Sebastien ARBOGAST wrote:
> I'm trying to create a postgis template database on a postgis server I
> just installed from source. I'm using postgresql-8.2.6 and
> postgis-1.3.2.
> But here is the log I get when I try to import lwpostgis.sql into my
> template_postgis database:
> $ psql -d template_postgis -f /usr/local/pgsql/share/lwpostgis.sql
> BEGIN
> psql:/usr/local/pgsql/share/lwpostgis.sql:44: NOTICE: Taper
> «histogram2d» n'est pas encore défini
> DETAIL: Création de la définition d'un shell type.
> psql:/usr/local/pgsql/share/lwpostgis.sql:50: ERREUR: La transaction
> courante est annulée, les commandes sont ignorées jusqu'à la fon du
> bloc de la transaction
My French is not so good but put /usr/local/pgsql/lib in /etc/ld.so.conf
(or /etc/ld.so.conf.d/<filename>.conf depending on distribution) and
then run ldconfig. That may solve the issue.
Regards,
Tim Bowden
> This error seems to be very frequent but I couldn't find any thread on
> a forum or mailing list where a final solution is suggested.
> FYI, here is the summary I get from postgis configure and liblwgeom.so
> is in /usr/local/pgsql/lib
> SUMMARY
> HOST_OS: linux-gnu
> PGSQL: /usr/local/pgsql/bin/pg_config
> GEOS: /usr/local/bin/geos-config (with C-API)
> (ldflags: -L/usr/local/lib)
> PROJ: prefix=/usr/local libdir=/usr/local/lib
> ICONV: 1
> PORTNAME: linux
> PREFIX: /usr/local/pgsql
> EPREFIX: ${prefix}
> DOC: /usr/local/pgsql/doc/contrib
> DATA: ${datarootdir}
> MAN: ${datarootdir}/man
> BIN: /usr/local/pgsql/bin
> EXT: /usr/local/pgsql/lib (\$$libdir)
> Please help.
