[postgis-users] psql:/usr/local/pgsql/share/lwpostgis.sql:44: ERREUR: Impossible d'accéder au fichier "$libdir/liblwgeom" : No such file or directory
Jean David TECHER
david.techer at davidgis.fr
Tue Jan 8 19:35:11 PST 2008
Tim is right.
If "/etc/ld.so.conf" is a file on your system then
do
echo "/usr/local/pgsql/lib" >> /etc/ld.so.conf
in order to adding this line to your file
then run
ldconfig
Kind regards
--david;
> On Tue, 2008-01-08 at 23:23 +0100, Sebastien ARBOGAST wrote:
>> I'm trying to create a postgis template database on a postgis server I
>> just installed from source. I'm using postgresql-8.2.6 and
>> postgis-1.3.2.
>> But here is the log I get when I try to import lwpostgis.sql into my
>> template_postgis database:
>> $ psql -d template_postgis -f /usr/local/pgsql/share/lwpostgis.sql
>> BEGIN
>> psql:/usr/local/pgsql/share/lwpostgis.sql:44: NOTICE: Taper
>> «histogram2d» n'est pas encore défini
>> DETAIL: Création de la définition d'un shell type.
>> psql:/usr/local/pgsql/share/lwpostgis.sql:50: ERREUR: La transaction
>> courante est annulée, les commandes sont ignorées jusqu'à la fon du
>> bloc de la transaction
> My French is not so good but put /usr/local/pgsql/lib in /etc/ld.so.conf
> (or /etc/ld.so.conf.d/<filename>.conf depending on distribution) and
> then run ldconfig. That may solve the issue.
> Regards,
> Tim Bowden
>> This error seems to be very frequent but I couldn't find any thread on
>> a forum or mailing list where a final solution is suggested.
>> FYI, here is the summary I get from postgis configure and liblwgeom.so
>> is in /usr/local/pgsql/lib
>> SUMMARY
>> HOST_OS: linux-gnu
>> PGSQL: /usr/local/pgsql/bin/pg_config
>> GEOS: /usr/local/bin/geos-config (with C-API)
>> (ldflags: -L/usr/local/lib)
>> PROJ: prefix=/usr/local libdir=/usr/local/lib
>> ICONV: 1
>> PORTNAME: linux
>> PREFIX: /usr/local/pgsql
>> EPREFIX: ${prefix}
>> DOC: /usr/local/pgsql/doc/contrib
>> DATA: ${datarootdir}
>> MAN: ${datarootdir}/man
>> BIN: /usr/local/pgsql/bin
>> EXT: /usr/local/pgsql/lib (\$$libdir)
>> Please help.
> postgis-users mailing list
Jean David TECHER
06 60 46 85 05
04 99 77 17 87
