Re: [postgis-users] psql:/usr/local/pgsql/share/lwpostgis.sql:44: ERREUR: Impossible d'accéder au fichier "$libdir/liblwgeom" : No such file or directory
Sebastien ARBOGAST
sebastien.arbogast at gmail.com
Wed Jan 9 02:09:58 PST 2008
I'm on Ubuntu 6.06 so indeed I have a /etc/ld.so.conf file.
I added pgsql lib directory to it and ran ldconfig, but it doesn't
solve my issue.
Do I have to reinstall Postgis all over again after running ldconfig?
2008/1/9, Jean David TECHER <david.techer at davidgis.fr>:
> Tim is right.
> If "/etc/ld.so.conf" is a file on your system then
> do
> echo "/usr/local/pgsql/lib" >> /etc/ld.so.conf
> in order to adding this line to your file
> then run
> ldconfig
> Kind regards
> --david;
> > On Tue, 2008-01-08 at 23:23 +0100, Sebastien ARBOGAST wrote:
> >> I'm trying to create a postgis template database on a postgis server I
> >> just installed from source. I'm using postgresql-8.2.6 and
> >> postgis-1.3.2.
> >> But here is the log I get when I try to import lwpostgis.sql into my
> >> template_postgis database:
> >> $ psql -d template_postgis -f /usr/local/pgsql/share/lwpostgis.sql
> >> BEGIN
> >> psql:/usr/local/pgsql/share/lwpostgis.sql:44: NOTICE: Taper
> >> «histogram2d» n'est pas encore défini
> >> DETAIL: Création de la définition d'un shell type.
> >> psql:/usr/local/pgsql/share/lwpostgis.sql:50: ERREUR: La transaction
> >> courante est annulée, les commandes sont ignorées jusqu'à la fon du
> >> bloc de la transaction
> > My French is not so good but put /usr/local/pgsql/lib in /etc/ld.so.conf
> > (or /etc/ld.so.conf.d/<filename>.conf depending on distribution) and
> > then run ldconfig. That may solve the issue.
> > Regards,
> > Tim Bowden
> >> This error seems to be very frequent but I couldn't find any thread on
> >> a forum or mailing list where a final solution is suggested.
> >> FYI, here is the summary I get from postgis configure and liblwgeom.so
> >> is in /usr/local/pgsql/lib
> >> SUMMARY
> >> HOST_OS: linux-gnu
> >> PGSQL: /usr/local/pgsql/bin/pg_config
> >> GEOS: /usr/local/bin/geos-config (with C-API)
> >> (ldflags: -L/usr/local/lib)
> >> PROJ: prefix=/usr/local libdir=/usr/local/lib
> >> ICONV: 1
> >> PORTNAME: linux
> >> PREFIX: /usr/local/pgsql
> >> EPREFIX: ${prefix}
> >> DOC: /usr/local/pgsql/doc/contrib
> >> DATA: ${datarootdir}
> >> MAN: ${datarootdir}/man
> >> BIN: /usr/local/pgsql/bin
> >> EXT: /usr/local/pgsql/lib (\$$libdir)
> >> Please help.
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
> Jean David TECHER
> 06 60 46 85 05
> 04 99 77 17 87
Sébastien Arbogast
http://www.sebastien-arbogast.com
