[postgis-users] Pipeline Data Model
Abram Gillespie
abe.gillespie.lists at gmail.com
Thu Jan 10 13:46:45 PST 2008
I'm not sure I get this. I know you can link - from Access - to a
Postgres table over ODBC. But are you saying you can push the table
definitions from Access into Postgres?
On Jan 10, 2008 3:48 PM, Burgholzer,Robert
<rwburgholzer at deq.virginia.gov> wrote:
> If you have set up an ODBC connection to your PostgreSQL database, the
> tables can be loaded into postgres from MSAccess by using Access's
> "Export" function. If there are spatial columns in there, this will be
> a difficulty, but the regular data will upload. Of course, any linkages
> will have to be reconstituted by hand, but it is a reasonable method in
> my experience.
> Robert W. Burgholzer
> Surface Water Modeler
> Office of Water Supply and Planning
> Virginia Department of Environmental Quality
> 804-698-4405
> Open Source Modeling Tools for NPS analysis and Water Supply Planning:
> http://sourceforge.net/projects/npsource/
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> George Silva
> Sent: Thursday, January 10, 2008 3:10 PM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] Pipeline Data Model
> Abe, here is the XML file. Its a product of ArcGis Diagrammer.
> Note: this is APDM version 2. I cant seem to build in version 4. Ill
> look into it.
> If you do build that code, i would to see it very much ;)
> Att.
> George
> postgis-users mailing list
