[postgis-users] Area calculation oh two polygon that they are overlapping
Guido Lemoine guido.lemoine at jrc.it
Fri Jan 11 01:19:50 PST 2008
SELECT ST_Area(ST_Intersection(GeomFromText('Polygon((0 0,0 3,3 3,3 0,0
0))'),
GeomFromText('Polygon((1 1,1 4,4 4,4 1,1 1))'))) --> 4 (QED)
SELECT ST_Area(ST_Union(GeomFromText('Polygon((0 0,0 3,3 3,3 0,0 0))'),
GeomFromText('Polygon((1 1,1 4,4 4,4 1,1 1))'))) --> 14
Paul Ramsey wrote:
> ST_Area(ST_Intersection(g1,g2)) ?
> On Jan 10, 2008, at 8:23 AM, olivier.amram at free.fr wrote:
>> Yes, but how do you calculate the area of the intersection ?
>> Olivier.
>> Selon Guido Lemoine <guido.lemoine at jrc.it>:
>>> Your multipolygon is simply two rings of 3 by 3. Defining them
>>> as multipolygon does do nothing for intersection, so the area is 18
>>> (which is 9 + 9). You need to look up what intersection means.
>>> For me, the intersection of the 2 polygons is the common area,
>>> which is 4.
>>> GL
>>>> Hi,
>>>> I'd like to compute the total area of polygon that intersects with
>>>> another
>>>> polygon
>>>> Polygon(0 0,0 3,3 3,3 0,0 0)
>>>> Polygon(1 1,4 1,4 4,1 4,1 1)
>>>> The total area is 14 but I don't find a solution to compute this
>>>> value.
>>>> e.g. SELECT Area(GeomFromText('MultiPolygon( ((0 0,0 3,3 3,3 0,0
>>>> 0)),((1
>>> 1,1 4,4
>>>> 4,4 1,1 1)))')) --> 18
>>>> Have you any idea ?
>>>> Thank,
>>>> Olivier.
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> postgis-users at postgis.refractions.net
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>>> Guido Lemoine
>>> Joint Research Centre, European Commission
>>> Institute for the Protection and Security of the Citizen (IPSC)
>>> Support to External Security
>>> Via E. Fermi, 2749 TP 267 Ispra 21027 (VA), Italy
>>> Tel. +39 0332 786239 (direct line) Fax. +39 0332 785154
>>> WWW: http://ses.jrc.it
>>> Disclaimer:
>>> Views expressed are those of the individual and do not represent
>>> the views of the European Commission
Guido Lemoine
Disclaimer:
