[postgis-users] degrees between points
Nicolas Ribot nicky666 at gmail.com
Wed Jan 16 09:06:45 PST 2008
> The following function seems to be the one:
> ST_azimuth(geometry, geometry)
> Returns the azimuth of the segment defined by the given Point
> geometries, or NULL if the two points are coincident. Return value is
> in radians.
Or azimuth():
select azimuth(geomfromtext('POINT (0 0)', 4326),
geomfromtext('POINT(90 90)', 4326));
      azimuth
 0.785398163397448
(1 row)
or
select degrees(azimuth(geomfromtext('POINT (0 0)', 4326),
geomfromtext('POINT(90 90)', 4326)));
      degrees
 45
(1 row)
Nicolas
