[postgis-users] How to use ST_Affine
Dylan Beaudette
dylan.beaudette at gmail.com
Wed Jan 16 13:52:06 PST 2008
On Wednesday 16 January 2008 09:09:01 am Frank Durstewitz wrote:
> Hi,
> i wonder how i would use ST_Affine. I found a small note how to use
> (with R), but that's over my mind.
> I want to shift the coordinates of some points. On a map i show the
> points, then i select at least 3 of them to move them manually to the
> correct coordinates and use the new coordinates as reference for the
> shift. So i have 3 "old" coordinates and 3 "new" cordinates. But i don't
> know what goes where...
> Can someone please explain what to do?
> Regards, Frank
Hi Frank,
Was it this page (http://casoilresource.lawr.ucdavis.edu/drupal/node/433)
which caused the confusion?
I was recently confronted with the same problem: I knew the locations
of 'good' and 'bad' coordinates (control points) but did not know how to
compute the transformation matrix, which ST_Affine() wants.
There are two approaches:
1. use R to 'fit' the transformation
2. use GRASS and v.transform to 'fit' the transformation
Both approaches can be used to compute and print the transformation matrix
based on a set of control points.
If you use R, the trick is interpreting the format of the transformation
matrix:
use the coef() function and transpose the results:
t(coef(l))
... and the format will be :
xoff a b
yoff d e
put the resulting numbers into the order that postgis wants:
ST_Affine(geom, a, b, d, e, xoff, yoff)
If you use GRASS and v.transform, be sure to include the '-m' flag, and the
transformation matrix will be printed, along with a note on the format.
As the linked page suggests this approach works well when there is a
systematic shift in coordinates which can be modeled by an affine transform.
Cheers,
Dylan
