[postgis-users] I've got a silly question about performance
easpengren phat-ass at thinkheavyindustries.com
Wed Jan 16 23:02:06 PST 2008
OK, I think I've got that. When I imported these shape files into the
database, an index was created. I added a Gist index to both to see what
would happen. Will that cause a problem?
I do not understand Indices at all. I'll have to read up on them.
We'll see how these things come out. I would like to have something usable
in the next day or two.
I'll likely end up creating a view of this query. Again, I'm still figuring
this out. Speed is really quite important for me. I don't have the most
powerful machine doing this stuff (more RAM will likely show up this week).
What I'd like to do is make sure the software is working as efficiently as I
can get it.
As I type this, I seem to have gotten a much quicker response from the
server.
Wow.
Eric
Brent Wood-2 wrote:
> --- easpengren <phat-ass at thinkheavyindustries.com> wrote:
>> I'm still getting the hang of some of the finer points of creating
>> queries in
>> PostGIS, as is probably obvious with my last post.
>> I've two tables, parcel2 that is a collection of parcels in a county and
>> a
>> table election, which is a table of voting precincts in the same county.
>> I'd
>> like to select all of the parcels in each precinct.
> That query looks OK, but if parcels can be split across precincts, then it
> won't necessarily give the correct answer.
>> I have this query:
>> select precinct, sit_st_num, sit_st_dir, sit_st_nam, sit_st_typ,
>> city_code
>> from election, parcel2 where ST_contains(election.the_geom,
>> ST_pointonsurface(parcel2.wkb_geometry));
>> This gets the job done, but it's very slow. What can I do to speed this
>> up?
> See the PostGIS docs about creating spatial indices on the geometry
> columns in
> your two tables.
> http://postgis.refractions.net/docs/ch04.html#id2761842
> http://postgis.refractions.net/docs/ch04.html#id2761985
> If you have, or if you create them, then you need to modify your query to
> use
> them:
> .... where election.the_geom && parcel2.wkb_geometry and ST_contains ...
> as described in:
> http://postgis.refractions.net/docs/ch04.html#id2762121
> Hope this helps...
>   Brent Wood
> postgis-users mailing list
View this message in context: http://www.nabble.com/I%27ve-got-a-silly-question-about-performance-tp14910258p14913339.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
