[postgis-users] I've got a silly question about performance
Brent Wood
pcreso at pcreso.com
Wed Jan 16 21:48:49 PST 2008
--- easpengren <phat-ass at thinkheavyindustries.com> wrote:
> I'm still getting the hang of some of the finer points of creating queries in
> PostGIS, as is probably obvious with my last post.
> I've two tables, parcel2 that is a collection of parcels in a county and a
> table election, which is a table of voting precincts in the same county. I'd
> like to select all of the parcels in each precinct.
That query looks OK, but if parcels can be split across precincts, then it
won't necessarily give the correct answer.
> I have this query:
> select precinct, sit_st_num, sit_st_dir, sit_st_nam, sit_st_typ, city_code
> from election, parcel2 where ST_contains(election.the_geom,
> ST_pointonsurface(parcel2.wkb_geometry));
> This gets the job done, but it's very slow. What can I do to speed this up?
See the PostGIS docs about creating spatial indices on the geometry columns in
your two tables.
http://postgis.refractions.net/docs/ch04.html#id2761842
http://postgis.refractions.net/docs/ch04.html#id2761985
If you have, or if you create them, then you need to modify your query to use
them:
.... where election.the_geom && parcel2.wkb_geometry and ST_contains ...
as described in:
http://postgis.refractions.net/docs/ch04.html#id2762121
Hope this helps...
Brent Wood
