[postgis-users] PostGIS / PostgreSQL binaries for RedHat/ItaniumII?
Paul Ramsey
pramsey at refractions.net
Fri Jan 18 11:31:31 PST 2008
The key thing to remember is that Fedora != Red Hat Enterprise Linux.
It will have different versions of things installed by default than
RHEL, and occasionally won't be compatible with binaries designed for
RHEL. Even though both come out of Red Hat.
RHEL tends to stick to old, known versions of libraries and so on.
Fedora tends to have newer versions. RHEL always takes the "safe,
stable" choice of what versions and packages to bundle. Fedora
sometimes tries the new-and-improved options.
Because it is slow to change, RHEL is the deployment standard for all
kinds of (binary, sometimes proprietary (read, Oracle)) software.
Centos is an unbranded version of RHEL. So if you make a binary on
Centos, it should deploy on RHEL, no problem.
With regard to compiling and using PostgreSQL and PostGIS from source
on Fedora or RHEL or Centos, it should not make any difference at
all. The only reason to get your knickers in a knot about distros is
if you know you are going to have to provide binary packages to a
client that will work on their systems, because if they are a large
organization using Linux, there is a very high probability it will be
RHEL.
Paul
On Jan 18, 2008, at 11:17 AM, Clay, Bruce wrote:
> Paul:
> Can you briefly explain how Centos differs from Fedora when it comes
> to using PostgreSql and PostGis?
> Bruce
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> Paul
> Ramsey
> Sent: Friday, January 18, 2008 11:28 AM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] PostGIS / PostgreSQL binaries for
> RedHat/ItaniumII?
> On Jan 18, 2008, at 5:56 AM, dnrg wrote:
>> Are there pre-compiled binaries available for
>> PostGIS/PostgreSQL for RedHat/Itanium II.
> Check with EnterpriseDB, they are the only ones I can imagine both
> with binaries for oddball architectures.
>> Is Itanium II
>> really such a rare/boutique platform as ESRI seems to
>> believe it to be by not supporting it fully?
> Yes, yes it is. I wouldn't spend any money on it, myself, until it
> proves itself in the market (and it has had a lot of time to do so,
> with little avail thus far). It might be great, but so was the DEC
> Alpha.
>> P.S. What's the "best" Enterpise class Linux for
>> PostGIS/PostgreSQL? I hear Centos and WhiteHat are
>> RedHat Enterprise without the logos.
> Centos I have heard of. WhiteHat I have not. Yes, that is what they
> are.
>> What Enterprise Linux do people here use for
>> PostGIS/PostgreSQL (for personal work where there is
>> little to no funding)?
> Centos.
> postgis-users mailing list
> This message and any enclosures are intended only for the
> addressee. Please
> notify the sender by email if you are not the intended recipient.
> If you are
> not the intended recipient, you may not use, copy, disclose, or
> distribute this
> message or its contents or enclosures to any other person and any
> such actions
> may be unlawful. Ball reserves the right to monitor and review all
> messages
> and enclosures sent to or from this email address.
