[postgis-users] newbie postgis and google maps question
Paul Ramsey
pramsey at refractions.net
Sun Jan 20 19:44:59 PST 2008
Mercator <> EPSG:4326
4326 is geographic coordinates on a WGS84 spheroid. Mercator is
projected coordinates still.
Either upload your shape file in the original coordinates, and then
transform in PostGIS:
shp2pgsql -D -i -s 2992 shpfile.shp tablename
select ST_AsText(ST_Transform(the_geom, 4326)) from tablename
Or do you ArcMap stuff but output in 4326 to start with.
Good luck!
P.
On Jan 20, 2008, at 7:39 PM, Sam Boggess wrote:
> The original shape file, that I got from the Oregon Forestry
> Department, had
> this projection:
> Data Type: Shapefile Feature Class
> Shapefile: Z:\FSN\seedzone_pre1996\sz_orwa_pre1996.shp
> Geometry Type: Polygon
> Projected Coordinate System:
> NAD_1983_Oregon_Statewide_Lambert_Feet_Intl
> Projection: Lambert_Conformal_Conic
> False_Easting: 1312335.95800525
> False_Northing: 0.00000000
> Central_Meridian: -120.50000000
> Standard_Parallel_1: 43.00000000
> Standard_Parallel_2: 45.50000000
> Latitude_Of_Origin: 41.75000000
> Linear Unit: Foot
> Geographic Coordinate System: GCS_North_American_1983
> Datum: D_North_American_1983
> Prime Meridian: 0
> Angular Unit: Degree
> So I projected that into mercator in ArcMap:
> Shapefile: Z:\FSN\seedzone_pre1996\sz_orwa_pre1996_Project.shp
> Projected Coordinate System: World_Mercator
> Projection: Mercator
> False_Easting: 0.00000000
> Central_Meridian: 0.00000000
> Standard_Parallel_1: 0.00000000
> Linear Unit: Meter
> Geographic Coordinate System: GCS_WGS_1984
> Datum: D_WGS_1984
> Prime Meridian: 0
> I then used shp2pgsql to add this to my database:
> SELECT AddGeometryColumn('members_oldzone', 'poly', 4326,
> 'MULTIPOLYGON',
> 2);
> ALTER TABLE "members_oldzone" ALTER "poly" SET NOT NULL;
> CREATE INDEX "members_oldzone_poly_id" ON "members_oldzone" USING
> GIST (
> "poly" GIST_GEOMETRY_OPS );
> Paul Ramsey wrote:
>> Your original data is probably not 4326. Do you have any clue what
>> projection it is in? Where did you get it from?
>> P
>> On Jan 20, 2008, at 7:02 PM, Sam Boggess wrote:
>>> Hello,
>>> I'm new to PostGIS and this has to be a cakewalk for
>>> you experienced users, but your help would be greatly
>>> appreciated. I
>>> have a PostGIS enabled database that contains polygon data from a
>>> shapefile using SRID 4326. All I want to do at this point is mark
>>> the
>>> centers of all of my polygons in Google Maps. I've written my
>>> query, and it works great:
>>> select astext(centroid(poly))
>>> from zones
>>> returns (a bunch of):
>>> POINT(-13057223.7425678 6208110.75868711)
>>> However, I have no idea what to do with this point data. Google
>>> maps
>>> expects lat and long; how can i convert this? In another forum a
>>> user
>>> suggested dividing by 10, but that's a point in Northern Canada,
>>> this point
>>> should be in NE Washington State.
>>> Any Help would be greatly appreciated
>>> View this message in context:
>>> http://www.nabble.com/newbie-postgis-and-google-maps-question-tp14989995p14989995.html
>>> Sent from the PostGIS - User mailing list archive at Nabble.com.
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> View this message in context: http://www.nabble.com/newbie-postgis-and-google-maps-question-tp14989995p14990735.html
