[postgis-users] newbie postgis and google maps question
Sam Boggess
sboggess at gmail.com
Sun Jan 20 20:07:13 PST 2008
Thank you so much! I'll try transforming it at the shp2pgsql stage.
In ArcMap does 4326 have a name? I can't find it?
Paul Ramsey wrote:
> Mercator <> EPSG:4326
> 4326 is geographic coordinates on a WGS84 spheroid. Mercator is
> projected coordinates still.
> Either upload your shape file in the original coordinates, and then
> transform in PostGIS:
> shp2pgsql -D -i -s 2992 shpfile.shp tablename
> select ST_AsText(ST_Transform(the_geom, 4326)) from tablename
> Or do you ArcMap stuff but output in 4326 to start with.
> Good luck!
> P.
> On Jan 20, 2008, at 7:39 PM, Sam Boggess wrote:
>> The original shape file, that I got from the Oregon Forestry
>> Department, had
>> this projection:
>> Data Type: Shapefile Feature Class
>> Shapefile: Z:\FSN\seedzone_pre1996\sz_orwa_pre1996.shp
>> Geometry Type: Polygon
>> Projected Coordinate System:
>> NAD_1983_Oregon_Statewide_Lambert_Feet_Intl
>> Projection: Lambert_Conformal_Conic
>> False_Easting: 1312335.95800525
>> False_Northing: 0.00000000
>> Central_Meridian: -120.50000000
>> Standard_Parallel_1: 43.00000000
>> Standard_Parallel_2: 45.50000000
>> Latitude_Of_Origin: 41.75000000
>> Linear Unit: Foot
>> Geographic Coordinate System: GCS_North_American_1983
>> Datum: D_North_American_1983
>> Prime Meridian: 0
>> Angular Unit: Degree
>> So I projected that into mercator in ArcMap:
>> Shapefile: Z:\FSN\seedzone_pre1996\sz_orwa_pre1996_Project.shp
>> Projected Coordinate System: World_Mercator
>> Projection: Mercator
>> False_Easting: 0.00000000
>> Central_Meridian: 0.00000000
>> Standard_Parallel_1: 0.00000000
>> Linear Unit: Meter
>> Geographic Coordinate System: GCS_WGS_1984
>> Datum: D_WGS_1984
>> Prime Meridian: 0
>> I then used shp2pgsql to add this to my database:
>> SELECT AddGeometryColumn('members_oldzone', 'poly', 4326,
>> 'MULTIPOLYGON',
>> 2);
>> ALTER TABLE "members_oldzone" ALTER "poly" SET NOT NULL;
>> CREATE INDEX "members_oldzone_poly_id" ON "members_oldzone" USING
>> GIST (
>> "poly" GIST_GEOMETRY_OPS );
>> Paul Ramsey wrote:
>>> Your original data is probably not 4326. Do you have any clue what
>>> projection it is in? Where did you get it from?
>>> P
>>> On Jan 20, 2008, at 7:02 PM, Sam Boggess wrote:
>>>> Hello,
>>>> I'm new to PostGIS and this has to be a cakewalk for
>>>> you experienced users, but your help would be greatly
>>>> appreciated. I
>>>> have a PostGIS enabled database that contains polygon data from a
>>>> shapefile using SRID 4326. All I want to do at this point is mark
>>>> the
>>>> centers of all of my polygons in Google Maps. I've written my
>>>> query, and it works great:
>>>> select astext(centroid(poly))
>>>> from zones
>>>> returns (a bunch of):
>>>> POINT(-13057223.7425678 6208110.75868711)
>>>> However, I have no idea what to do with this point data. Google
>>>> maps
>>>> expects lat and long; how can i convert this? In another forum a
>>>> user
>>>> suggested dividing by 10, but that's a point in Northern Canada,
>>>> this point
>>>> should be in NE Washington State.
>>>> Any Help would be greatly appreciated
>>>> View this message in context:
>>>> http://www.nabble.com/newbie-postgis-and-google-maps-question-tp14989995p14989995.html
>>>> Sent from the PostGIS - User mailing list archive at Nabble.com.
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> postgis-users at postgis.refractions.net
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> http://www.nabble.com/newbie-postgis-and-google-maps-question-tp14989995p14990735.html
View this message in context: http://www.nabble.com/newbie-postgis-and-google-maps-question-tp14989995p14990938.html
