[postgis-users] Error while MapInfo file to PostGIS
Surachai Locharoen
kan2005 at gmail.com
Tue Jan 22 02:34:30 PST 2008
I import file in MapInfo format into PostGIS by using ogr2ogr
Example
export PGCLIENTENCODING=WIN874 // I import file which use this
encoding.
ogr2ogr -append -skipfailures -f "PostgreSQL" PG:dbname=MapDB
ADMIN_BND.TAB -nln ADMIN_BND
The map is composed in many file So I have write python script to import
file. I import one file per table.
While I import I found these error
- ERROR: new row for relation "ROADCL" violates check constraint
"enforce_geotype_wkb_geometry"
- Error: Character 0x81 in WIN874 encoding cound not mach any character in
UTF-8 encoding.
- ERROR: geometry requires more points
I have very headache. Could you sugest a solution or tool to convert a
mapinfo to postgis
Surachai Locharoen
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080122/b79f2477/attachment.html>
