[postgis-users] Intersection Problem
Frank Koormann
frank.koormann at intevation.de
Wed Jan 23 01:26:18 PST 2008
* Christian Niemitz-Rossant <cnr at m-click.de> [080122 22:33]:
> we are dealing with a similar problem "The intersection of a 3D line and a
> 2D polygon returns a 3D line with some problems":
> So far we got these results:
> 1. Points of the line inside the polygon (Z-projection) have the correct
> z-value which is simply unmodified.
> 2. The calculated intersection points of the line with the polygon have a
> z-value which is half of the expected result.
> 3. If the calculated intersection point has the same xy-coordinates as one
> point of the polygon then returned z-value is zero!
> We would appreciate hints, ideas or answers. Thanks!
Could you provide more information, e.g. the GEOS version you use and a
simple example showing the problem?
Regards,
Frank
Frank Koormann | ++49-541-335 08 30 | http://www.intevation.net/
Intevation GmbH, Osnabrück, DE | Commercial Register Osnabrück, HR B 18998
Managing Directors: Frank Koormann, Bernhard Reiter, Dr. Jan-Oliver Wagner
PostGIS Support (http://www.intevation.net/geospatial/postgis-support.en.html)
