[postgis-users] Trigger Function for Updating Geom
Kevin Neufeld
kneufeld at refractions.net
Wed Jan 23 08:31:32 PST 2008
Also, in your case, I would recommend using a RULE instead of a TRIGGER
- it could be much faster.
http://www.postgresql.org/docs/8.2/static/rules-triggers.html
http://www.postgresql.org/docs/8.2/static/sql-createrule.html
A trigger is fired on every row affected. So in your case, if you update
a row in your table, postgres inserts a new row into the table and
deletes the old row flagging it as a dead tuple. Then the trigger fires
on the row and another insert and delete operation is performed. That's
2 inserts and 2 deletes - a rather expensive update operation.
On the other hand, a rule simply rewrites the query once at the
beginning, leaving you with one update operation.
Following the docs, your rule might be something like:
CREATE OR REPLACE RULE make_geom_rule AS
ON INSERT TO hyd
DO INSTEAD
INSERT INTO hyd (field1, ..., hydgeom) VALUES
(NEW.field1, ..., SetSRID(ST_MakePoint(NEW.longitude,
NEW.latitude), 8307));
-- Kevin
Obe, Regina wrote:
> It should be
> NEW.hydgeom :=
> You have an = there (which would evaluate to a boolean of some sort)
> instead of plpgsql assignment :=
> Also I think using makepoint is more efficient,shorter to write, and
> easier to read
> So would be
> CREATE or replace FUNCTION make_geom () RETURNS trigger as
> $BODY$
> BEGIN
> NEW.hydgeom := SetSRID(makepoint(NEW.longitude, NEW.latitude), 8307);
> RETURN NEW;
> END
> $BODY$
> LANGUAGE plpgsql;
> Hope that helps,
> Regina
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> Willem Buitendyk
> Sent: Wednesday, January 23, 2008 4:20 AM
> To: rindahl at lrcwe.com; PostGIS Users Discussion
> Subject: Re: [postgis-users] Trigger Function for Updating Geom
> What you revised makes more sense; however, the problem now is that the
> geom column does not update at all. I modified the function to include
> RETURN NEW;
> $BODY$
> BEGIN
> NEW.hydgeom = GeometryFromText('POINT (' || cast(NEW.longitude as
> varchar(10)) || ' ' || cast(NEW.latitude as varchar(10)) || ')', 8307);
> RETURN NEW;
> END
> $BODY$
> LANGUAGE plpgsql;
> CREATE TRIGGER make_geom_trigger AFTER INSERT OR UPDATE ON hyd FOR EACH
> ROW EXECUTE PROCEDURE make_geom();
> Any ideas?
> Cheers
> Bruce Rindahl wrote:
>> Try:
>> $BODY$
>> BEGIN
> 8307);
>> END
>> $BODY$
>> LANGUAGE plpgsql;
>> This will update each row as it is processed. What you were doing was
>> trying to update EVERY row as EACH one was processed.
>> Bruce Rindahl
> Willem
>> Buitendyk
>> Sent: Tuesday, January 22, 2008 2:17 PM
>> To: postgis-users at postgis.refractions.net
>> Subject: [postgis-users] Trigger Function for Updating Geom
>> Hi there,
>> I am trying to figure out how to go about creating a trigger that
>> updates the geom on each insert. Currently, I am using the following
>> update statement on the table after bulk loading data in:
>> update temp_hyd set hydgeom = GeometryFromText('POINT (' ||
>> cast(longitude as varchar(10)) || ' ' || cast(latitude as varchar(10))
>> || ')', 8307);
>> I admit to feeling a little lost as I am only now just starting to
>> migrate GIS data into a server. So using relational databases are a
>> little new to me (and I don't think Access counts). I am hoping that
> only
>> updating those newly inserted records will be a whole lot faster then
>> redoing the whole table.
>> Here is what I have so far:
>> $BODY$
>> BEGIN
>> update hyd set hydgeom = GeometryFromText('POINT (' || cast(longitude
> as
>> varchar(10)) || ' ' || cast(latitude as varchar(10)) || ')', 8307);
>> END
>> $BODY$
>> LANGUAGE plpgsql;
> EACH
>> And of course it doesn't work. I get the following after doing an
>> insert statement:
>> ERROR: stack depth limit exceeded
>> SQL state: 54001
>> Hint: Increase the configuration parameter "max_stack_depth", after
>> ensuring the platform's stack depth limit is adequate.
>> Context: SQL statement "update hyd set hydgeom =
>> (' || cast(longitude as varchar(10)) || ' ' || cast(latitude as
>> varchar(10)) || ')', 8307)"
>> Appreciate any help with this,
>> Willem
>> postgis-users mailing list
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended
> solely for the addressee. If you received this in error, please
> contact the sender and delete the material from any computer.
