[postgis-users] Trigger Function for Updating Geom
Willem Buitendyk willem at pcfish.ca
Wed Jan 23 09:07:45 PST 2008
I tried using the rule instead but get this as an error message:
Error - 2008/01/23 09:02:49 - Line 1: ERROR:  infinite recursion
detected in rules for relation "hyd"
Kevin Neufeld wrote:
> Also, in your case, I would recommend using a RULE instead of a
> TRIGGER - it could be much faster.
> http://www.postgresql.org/docs/8.2/static/rules-triggers.html
> http://www.postgresql.org/docs/8.2/static/sql-createrule.html
> A trigger is fired on every row affected. So in your case, if you
> update a row in your table, postgres inserts a new row into the table
> and deletes the old row flagging it as a dead tuple.  Then the trigger
> fires on the row and another insert and delete operation is
> performed.  That's 2 inserts and 2 deletes - a rather expensive update
> operation.
> On the other hand, a rule simply rewrites the query once at the
> beginning, leaving you with one update operation.
> Following the docs, your rule might be something like:
> CREATE OR REPLACE RULE make_geom_rule AS
>  ON INSERT TO hyd
>  DO INSTEAD
>    INSERT INTO hyd (field1, ..., hydgeom) VALUES
>      (NEW.field1, ..., SetSRID(ST_MakePoint(NEW.longitude,
> NEW.latitude), 8307));
> -- Kevin
> Obe, Regina wrote:
>> It should be
>> NEW.hydgeom :=
>> You have an = there (which would evaluate to a boolean of some sort)
>> instead of plpgsql assignment :=
>> Also I think using makepoint is more efficient,shorter to write, and
>> easier to read
>> So would be
>> CREATE or replace FUNCTION make_geom () RETURNS trigger as
>> $BODY$
>> BEGIN
>> NEW.hydgeom := SetSRID(makepoint(NEW.longitude, NEW.latitude), 8307);
>> RETURN NEW;
>> END
>> $BODY$
>> LANGUAGE plpgsql;
>> Hope that helps,
>> Regina
>> -----Original Message-----
>> From: postgis-users-bounces at postgis.refractions.net
>> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
>> Willem Buitendyk
>> Sent: Wednesday, January 23, 2008 4:20 AM
>> To: rindahl at lrcwe.com; PostGIS Users Discussion
>> Subject: Re: [postgis-users] Trigger Function for Updating Geom
>> What you revised makes more sense;  however, the problem now is that the
>> geom column does not update at all.  I modified the function to include
>> RETURN NEW;
>> $BODY$
>> BEGIN
>> NEW.hydgeom = GeometryFromText('POINT (' || cast(NEW.longitude as
>> varchar(10)) || ' ' || cast(NEW.latitude as varchar(10)) || ')', 8307);
>> RETURN NEW;
>> END
>> $BODY$
>> LANGUAGE plpgsql;
>> CREATE TRIGGER make_geom_trigger AFTER INSERT OR UPDATE ON hyd FOR
>> EACH ROW EXECUTE PROCEDURE make_geom();
>> Any ideas?
>> Cheers
>> Bruce Rindahl wrote:
>>> Try:
>>> $BODY$
>>> BEGIN
>> 8307);
>>> END
>>> $BODY$
>>> LANGUAGE plpgsql;
>>>   This will update each row as it is processed.  What you were doing
>>> was
>>> trying to update EVERY row as EACH one was processed.
>>> Bruce Rindahl
>> Willem
>>> Buitendyk
>>> Sent: Tuesday, January 22, 2008 2:17 PM
>>> To: postgis-users at postgis.refractions.net
>>> Subject: [postgis-users] Trigger Function for Updating Geom
>>> Hi there,
>>> I am trying to figure out how to go about creating a trigger that
>>> updates the geom on each insert.  Currently, I am using the
>>> following update statement on the table after bulk loading data in:
>>> update temp_hyd set hydgeom = GeometryFromText('POINT (' ||
>>> cast(longitude as varchar(10)) || ' ' || cast(latitude as varchar(10))
>>> || ')', 8307);
>>> I admit to feeling a little lost as I am only now just starting to
>>> migrate GIS data into a server.  So using relational databases are a
>>> little new to me (and I don't think Access counts).  I am hoping that
>> only
>>> updating those newly inserted records will be a whole lot faster
>>> then redoing the whole table.
>>> Here is what I have so far:
>>> $BODY$
>>> BEGIN
>>> update hyd set hydgeom = GeometryFromText('POINT (' || cast(longitude
>> as
>>> varchar(10)) || ' ' || cast(latitude as varchar(10)) || ')', 8307);
>>> END
>>> $BODY$
>>> LANGUAGE plpgsql;
>> EACH
>>> And of course it doesn't work.  I get the following after doing an
>>> insert statement:
>>> ERROR: stack depth limit exceeded
>>> SQL state: 54001
>>> Hint: Increase the configuration parameter "max_stack_depth", after
>>> ensuring the platform's stack depth limit is adequate.
>>> Context: SQL statement "update hyd set hydgeom =
>>> (' || cast(longitude as varchar(10)) || ' ' || cast(latitude as
>>> varchar(10)) || ')', 8307)"
>>> Appreciate any help with this,
>>> Willem
>>> postgis-users mailing list
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> The substance of this message, including any attachments, may be
>> confidential, legally privileged and/or exempt from disclosure
>> pursuant to Massachusetts law. It is intended
>> solely for the addressee. If you received this in error, please
>> contact the sender and delete the material from any computer.
