[postgis-users] Trigger Function for Updating Geom
Kevin Neufeld
kneufeld at refractions.net
Wed Jan 23 09:14:08 PST 2008
:) well, yes, that would make sense.
I commonly use rules with table partitioning ... where I'm inserting
into different tables. I suppose you could set it up so that all
inserts are performed by inserting into a second tmp_hyd table, but that
sounds like a hack.
ok, never mind. :)
Willem Buitendyk wrote:
> I tried using the rule instead but get this as an error message:
> Error - 2008/01/23 09:02:49 - Line 1: ERROR: infinite recursion
> detected in rules for relation "hyd"
> Kevin Neufeld wrote:
>> Also, in your case, I would recommend using a RULE instead of a
>> TRIGGER - it could be much faster.
>> http://www.postgresql.org/docs/8.2/static/rules-triggers.html
>> http://www.postgresql.org/docs/8.2/static/sql-createrule.html
>> A trigger is fired on every row affected. So in your case, if you
>> update a row in your table, postgres inserts a new row into the table
>> and deletes the old row flagging it as a dead tuple. Then the
>> trigger fires on the row and another insert and delete operation is
>> performed. That's 2 inserts and 2 deletes - a rather expensive
>> update operation.
>> On the other hand, a rule simply rewrites the query once at the
>> beginning, leaving you with one update operation.
>> Following the docs, your rule might be something like:
>> CREATE OR REPLACE RULE make_geom_rule AS
>> ON INSERT TO hyd
>> DO INSTEAD
>> INSERT INTO hyd (field1, ..., hydgeom) VALUES
>> (NEW.field1, ..., SetSRID(ST_MakePoint(NEW.longitude,
>> NEW.latitude), 8307));
>> -- Kevin
>> Obe, Regina wrote:
>>> It should be
>>> NEW.hydgeom := You have an = there (which would evaluate to a
>>> boolean of some sort)
>>> instead of plpgsql assignment :=
>>> Also I think using makepoint is more efficient,shorter to write, and
>>> easier to read
>>> So would be
>>> CREATE or replace FUNCTION make_geom () RETURNS trigger as
>>> $BODY$
>>> BEGIN
>>> NEW.hydgeom := SetSRID(makepoint(NEW.longitude, NEW.latitude), 8307);
>>> RETURN NEW;
>>> END
>>> $BODY$
>>> LANGUAGE plpgsql;
>>> Hope that helps,
>>> Regina
>>> -----Original Message-----
>>> From: postgis-users-bounces at postgis.refractions.net
>>> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
>>> Willem Buitendyk
>>> Sent: Wednesday, January 23, 2008 4:20 AM
>>> To: rindahl at lrcwe.com; PostGIS Users Discussion
>>> Subject: Re: [postgis-users] Trigger Function for Updating Geom
>>> What you revised makes more sense; however, the problem now is that
>>> the
>>> geom column does not update at all. I modified the function to include
>>> RETURN NEW;
>>> $BODY$
>>> BEGIN
>>> NEW.hydgeom = GeometryFromText('POINT (' || cast(NEW.longitude as
>>> varchar(10)) || ' ' || cast(NEW.latitude as varchar(10)) || ')', 8307);
>>> RETURN NEW;
>>> END
>>> $BODY$
>>> LANGUAGE plpgsql;
>>> CREATE TRIGGER make_geom_trigger AFTER INSERT OR UPDATE ON hyd FOR
>>> EACH ROW EXECUTE PROCEDURE make_geom();
>>> Any ideas?
>>> Cheers
>>> Bruce Rindahl wrote:
>>>> Try:
>>>> $BODY$
>>>> BEGIN
>>> 8307);
>>>> END
>>>> $BODY$
>>>> LANGUAGE plpgsql;
>>>> This will update each row as it is processed. What you were
>>>> doing was
>>>> trying to update EVERY row as EACH one was processed.
>>>> Bruce Rindahl
>>> Willem
>>>> Buitendyk
>>>> Sent: Tuesday, January 22, 2008 2:17 PM
>>>> To: postgis-users at postgis.refractions.net
>>>> Subject: [postgis-users] Trigger Function for Updating Geom
>>>> Hi there,
>>>> I am trying to figure out how to go about creating a trigger that
>>>> updates the geom on each insert. Currently, I am using the
>>>> following update statement on the table after bulk loading data in:
>>>> update temp_hyd set hydgeom = GeometryFromText('POINT (' ||
>>>> cast(longitude as varchar(10)) || ' ' || cast(latitude as varchar(10))
>>>> || ')', 8307);
>>>> I admit to feeling a little lost as I am only now just starting to
>>>> migrate GIS data into a server. So using relational databases are
>>>> a little new to me (and I don't think Access counts). I am hoping
>>>> that
>>> only
>>>> updating those newly inserted records will be a whole lot faster
>>>> then redoing the whole table.
>>>> Here is what I have so far:
>>>> $BODY$
>>>> BEGIN
>>>> update hyd set hydgeom = GeometryFromText('POINT (' || cast(longitude
>>> as
>>>> varchar(10)) || ' ' || cast(latitude as varchar(10)) || ')', 8307);
>>>> END
>>>> $BODY$
>>>> LANGUAGE plpgsql;
>>> EACH
>>>> And of course it doesn't work. I get the following after doing an
>>>> insert statement:
>>>> ERROR: stack depth limit exceeded
>>>> SQL state: 54001
>>>> Hint: Increase the configuration parameter "max_stack_depth", after
>>>> ensuring the platform's stack depth limit is adequate.
>>>> Context: SQL statement "update hyd set hydgeom =
>>>> (' || cast(longitude as varchar(10)) || ' ' || cast(latitude as
>>>> varchar(10)) || ')', 8307)"
>>>> Appreciate any help with this,
>>>> Willem
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>>> The substance of this message, including any attachments, may be
>>> confidential, legally privileged and/or exempt from disclosure
>>> pursuant to Massachusetts law. It is intended
>>> solely for the addressee. If you received this in error, please
>>> contact the sender and delete the material from any computer.
