[postgis-users] Trigger Function for Updating Geom
Willem Buitendyk willem at pcfish.ca
Wed Jan 23 20:36:29 PST 2008
Success.  To get it to update the geom I had to change my trigger to
insert before - not after.
>> Obe, Regina wrote:
>>> It should be
>>> NEW.hydgeom := You have an = there (which would evaluate to a
>>> boolean of some sort)
>>> instead of plpgsql assignment :=
>>> Also I think using makepoint is more efficient,shorter to write, and
>>> easier to read
>>> So would be
>>> CREATE or replace FUNCTION make_geom () RETURNS trigger as
>>> $BODY$
>>> BEGIN
>>> NEW.hydgeom := SetSRID(makepoint(NEW.longitude, NEW.latitude), 8307);
>>> RETURN NEW;
>>> END
>>> $BODY$
>>> LANGUAGE plpgsql;
>>> Hope that helps,
>>> Regina
>>> -----Original Message-----
>>> From: postgis-users-bounces at postgis.refractions.net
>>> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
>>> Willem Buitendyk
>>> Sent: Wednesday, January 23, 2008 4:20 AM
>>> To: rindahl at lrcwe.com; PostGIS Users Discussion
>>> Subject: Re: [postgis-users] Trigger Function for Updating Geom
>>> What you revised makes more sense;  however, the problem now is that
>>> the
>>> geom column does not update at all.  I modified the function to include
>>> RETURN NEW;
>>> $BODY$
>>> BEGIN
>>> NEW.hydgeom = GeometryFromText('POINT (' || cast(NEW.longitude as
>>> varchar(10)) || ' ' || cast(NEW.latitude as varchar(10)) || ')', 8307);
>>> RETURN NEW;
>>> END
>>> $BODY$
>>> LANGUAGE plpgsql;
>>> CREATE TRIGGER make_geom_trigger AFTER INSERT OR UPDATE ON hyd FOR
>>> EACH ROW EXECUTE PROCEDURE make_geom();
>>> Any ideas?
>>> Cheers
>>> Bruce Rindahl wrote:
>>>> Try:
>>>> $BODY$
>>>> BEGIN
>>> 8307);
>>>> END
>>>> $BODY$
>>>> LANGUAGE plpgsql;
>>>>   This will update each row as it is processed.  What you were
>>>> doing was
>>>> trying to update EVERY row as EACH one was processed.
>>>> Bruce Rindahl
>>> Willem
>>>> Buitendyk
>>>> Sent: Tuesday, January 22, 2008 2:17 PM
>>>> To: postgis-users at postgis.refractions.net
>>>> Subject: [postgis-users] Trigger Function for Updating Geom
>>>> Hi there,
>>>> I am trying to figure out how to go about creating a trigger that
>>>> updates the geom on each insert.  Currently, I am using the
>>>> following update statement on the table after bulk loading data in:
>>>> update temp_hyd set hydgeom = GeometryFromText('POINT (' ||
>>>> cast(longitude as varchar(10)) || ' ' || cast(latitude as varchar(10))
>>>> || ')', 8307);
>>>> I admit to feeling a little lost as I am only now just starting to
>>>> migrate GIS data into a server.  So using relational databases are
>>>> a little new to me (and I don't think Access counts).  I am hoping
>>>> that
>>> only
>>>> updating those newly inserted records will be a whole lot faster
>>>> then redoing the whole table.
>>>> Here is what I have so far:
>>>> $BODY$
>>>> BEGIN
>>>> update hyd set hydgeom = GeometryFromText('POINT (' || cast(longitude
>>> as
>>>> varchar(10)) || ' ' || cast(latitude as varchar(10)) || ')', 8307);
>>>> END
>>>> $BODY$
>>>> LANGUAGE plpgsql;
>>> EACH
>>>> And of course it doesn't work.  I get the following after doing an
>>>> insert statement:
>>>> ERROR: stack depth limit exceeded
>>>> SQL state: 54001
>>>> Hint: Increase the configuration parameter "max_stack_depth", after
>>>> ensuring the platform's stack depth limit is adequate.
>>>> Context: SQL statement "update hyd set hydgeom =
>>>> (' || cast(longitude as varchar(10)) || ' ' || cast(latitude as
>>>> varchar(10)) || ')', 8307)"
>>>> Appreciate any help with this,
>>>> Willem
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>>> The substance of this message, including any attachments, may be
>>> confidential, legally privileged and/or exempt from disclosure
>>> pursuant to Massachusetts law. It is intended
>>> solely for the addressee. If you received this in error, please
>>> contact the sender and delete the material from any computer.
