[postgis-users] Trigger Function for Updating Geom
Bruce Rindahl rindahl at lrcwe.com
Wed Jan 23 09:20:01 PST 2008
And the trigger...
-- Trigger: well_update on wells
-- DROP TRIGGER well_update ON wells;
CREATE TRIGGER well_update
  BEFORE INSERT
  ON wells
  FOR EACH ROW
  EXECUTE PROCEDURE check_well_ids();
Bruce
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Bruce
Rindahl
Sent: Wednesday, January 23, 2008 10:17 AM
To: 'PostGIS Users Discussion'
Subject: RE: [postgis-users] Trigger Function for Updating Geom
Well here is my trigger function which does work:
-- Function: check_well_ids()
-- DROP FUNCTION check_well_ids();
CREATE OR REPLACE FUNCTION check_well_ids()
  RETURNS "trigger" AS
$BODY$
  DECLARE
  BEGIN
    if (NEW.utm_x > 0 and NEW.utm_y > 0) then
	NEW.the_geom = setSRID(MakePoint(NEW.utm_x,NEW.utm_y),26913);
	NEW.latdecdeg = y(transform(NEW.the_geom,4326));
	NEW.longdecdeg = x(transform(NEW.the_geom,4326));
    end if;
    RETURN NEW;
  END;
$BODY$
  LANGUAGE 'plpgsql' VOLATILE;
ALTER FUNCTION check_well_ids() OWNER TO postgres;
My updates give all attributes including utm_x and utm_y.  The trigger
function updates the_geom and computes the lat/long values on the fly and is
very fast (450,000 row table).
Bruce
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Willem
Buitendyk
Sent: Wednesday, January 23, 2008 10:10 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Trigger Function for Updating Geom
I was unaware of makepoint.  I agree it is easier to work with.
However, same problem as before.  It doesn't seem to work with the
function I created.  It will work no problem if I use an update
statement.  Strange
Obe, Regina wrote:
> It should be
> NEW.hydgeom :=
> You have an = there (which would evaluate to a boolean of some sort)
> instead of plpgsql assignment :=
> Also I think using makepoint is more efficient,shorter to write, and
> easier to read
> So would be
> CREATE or replace FUNCTION make_geom () RETURNS trigger as
> $BODY$
> BEGIN
> NEW.hydgeom := SetSRID(makepoint(NEW.longitude, NEW.latitude), 8307);
> RETURN NEW;
> END
> $BODY$
> LANGUAGE plpgsql;
> Hope that helps,
> Regina
> Willem Buitendyk
> Sent: Wednesday, January 23, 2008 4:20 AM
> To: rindahl at lrcwe.com; PostGIS Users Discussion
> What you revised makes more sense;  however, the problem now is that the
> geom column does not update at all.  I modified the function to include
> RETURN NEW;
> $BODY$
> BEGIN
> NEW.hydgeom = GeometryFromText('POINT (' || cast(NEW.longitude as
> varchar(10)) || ' ' || cast(NEW.latitude as varchar(10)) || ')', 8307);
> RETURN NEW;
> END
> $BODY$
> LANGUAGE plpgsql;
> CREATE TRIGGER make_geom_trigger AFTER INSERT OR UPDATE ON hyd FOR EACH
> ROW EXECUTE PROCEDURE make_geom();
> Any ideas?
> Cheers
> Bruce Rindahl wrote:
>> Try:
>> $BODY$
>> BEGIN
> 8307);
>> END
>> $BODY$
>> LANGUAGE plpgsql;
>> This will update each row as it is processed.  What you were doing was
>> trying to update EVERY row as EACH one was processed.
>> Bruce Rindahl
> Willem
>> Buitendyk
>> Sent: Tuesday, January 22, 2008 2:17 PM
>> To: postgis-users at postgis.refractions.net
>> Subject: [postgis-users] Trigger Function for Updating Geom
>> Hi there,
>> I am trying to figure out how to go about creating a trigger that
>> updates the geom on each insert.  Currently, I am using the following
>> update statement on the table after bulk loading data in:
>> update temp_hyd set hydgeom = GeometryFromText('POINT (' ||
>> cast(longitude as varchar(10)) || ' ' || cast(latitude as varchar(10))
>> || ')', 8307);
>> I admit to feeling a little lost as I am only now just starting to
>> migrate GIS data into a server.  So using relational databases are a
>> little new to me (and I don't think Access counts).  I am hoping that
> only
>> updating those newly inserted records will be a whole lot faster then
>> redoing the whole table.
>> Here is what I have so far:
>> $BODY$
>> BEGIN
>> update hyd set hydgeom = GeometryFromText('POINT (' || cast(longitude
> as
>> varchar(10)) || ' ' || cast(latitude as varchar(10)) || ')', 8307);
>> END
>> $BODY$
>> LANGUAGE plpgsql;
> EACH
>> And of course it doesn't work.  I get the following after doing an
>> insert statement:
>> ERROR: stack depth limit exceeded
>> SQL state: 54001
>> Hint: Increase the configuration parameter "max_stack_depth", after
>> ensuring the platform's stack depth limit is adequate.
>> Context: SQL statement "update hyd set hydgeom =
>> (' || cast(longitude as varchar(10)) || ' ' || cast(latitude as
>> varchar(10)) || ')', 8307)"
>> Appreciate any help with this,
>> Willem
>> postgis-users mailing list
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended
> solely for the addressee. If you received this in error, please
> contact the sender and delete the material from any computer.
