[postgis-users] Faster point polygon query
Dan Erikson
dan.erikson at timberline.ca
Wed Jan 23 14:07:34 PST 2008
Thanks for the replies already. I do have clustered spatial indexes on
each of the tables. I'll check out the simplify, and do some testing on
that.
Thanks again.
Dan Erikson BNRSc
Timberline Natural Resource Group
(250)-314-0875 ext 240
www.timberline.ca
Burgholzer,Robert wrote:
> Make sure that you have spatial indices on the geom columns in each
> table. If that is already the case, the most likely culprit is extremely
> complex polygon shapes, which the containment algorithms are not suited
> to do quickly (although it might be the fastest algorithm possible).
> Suggestions that have come up in the past were to use the "simplify()"
> function to remove extraneous edges from your polygons, making the query
> faster.
> Robert W. Burgholzer
> Surface Water Modeler
> Office of Water Supply and Planning
> Virginia Department of Environmental Quality
> rwburgholzer at deq.virginia.gov
> 804-698-4405
> Open Source Modeling Tools:
> http://sourceforge.net/projects/npsource/
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Dan
> Erikson
> Sent: Wednesday, January 23, 2008 4:34 PM
> To: PostGIS Users Discussion
> Subject: [postgis-users] Faster point polygon query
> I need to relate two spatial datasets. One dataset is a point dataset
> (~200 Million records), the other is a polygon dataset (~500,000
> records). The result of these queries is to be a non-spatial table
> listing the id's ("tid" in this case) from each table where there is a
> spatial join. I have tried both ST_Within and ST_Distance, and both
> queries are incredibly slow (> 100 hours). Running on a very capable
> server. Any ideas on faster methods to complete this query?
> Thanks!
> CREATE TABLE public.step2 as
> (SELECT mp.pntgrid_10_tid AS pntgrid_10_tid,
> vri.tid AS vri_tid
> FROM grids.tbl_mtsa_pnts mp, vri.tbl_vri vri
> WHERE mp.geom && vri.geom
> AND ST_Within(mp.geom, vri.geom));
> vri.tid AS vri_tid
> AND ST_Distance(mp.geom, vri.geom) = 0);
