[postgis-users] Spatial query Help: points not in set of polygons
Stephen Woodbridge
woodbri at swoodbridge.com
Wed Jan 23 19:26:59 PST 2008
Hi all,
I'm drawing a blank on setting up a query for this.
I have a tables points and a table of polygons. I need to find all the
points that are not in any of the polygons.
select a.*
from points a, polygons b
where a.the_geom && b.the_geom
and distance(a.the_geom, b.the_geom) > 0.0;
The problem with this is that if a point is in polygon A it will have a
distance to polygon B, so this in no good.
I thought of doing something like:
select * from points
where distance(the_geom, union((select the_geom from polygons))) > 0.0;
or
where distance(the_geom, collect((select the_geom from polygons))) > 0.0;
So is there a better way to do this. Seems like there should be. If not
which of these would you suggest.
Thanks,
-Steve
