[postgis-users] Affine transformations of GIS data.
Frank Durstewitz
frank.durstewitz at emporis.com
Thu Jan 24 23:22:14 PST 2008
Good news, Bruce!
I will use this with googlemaps and ajax. Best case for me would be to
be without additional table, but to give 2 collection of points (one
with the "bad", one with the "good" coordinates) and simply return the
coefs for use with ST_Affine.
Regards, Frank
Bruce Rindahl schrieb:
> Based on a previous post on affine transformations of GIS data in PostGIS, I
> have put together a function that takes a table of control points and
> computes the affine transformation coefficients using the least squares code
> from GRASS. A nice tutorial by Dylan Beaudette on this is at:
> http://casoilresource.lawr.ucdavis.edu/drupal/node/433
> At this point I would like some feed back on how this could be used. I
> envision a GIS package (say uDIG) would allow a user to select pairs of
> points and populate a table with a similar layout as ESRI's link table when
> georeferencing. A query would give the RMS error and similar query would
> return the table back with the residual errors. If the user were then happy
> with the values (after deleting poor matching points), a final query could
> then be made to the ST_Affine function to modify the geometry based on the
> control points.
> Comments?
> Bruce Rindahl
> postgis-users mailing list
Mit freundlichen Gruessen / kind regards
Frank Durstewitz
Emporis GmbH
Robert-Bosch-Strasse 7
D-64293 Darmstadt
Germany
Tel +49(0)6151 5001769
Fax +49(0)6151 5001799
E-Mail frank.durstewitz at emporis.com
http://corporate.emporis.com
[Emporis is one of the world's leading providers of building-related
information]
