[postgis-users] Strange performance issue
Claire McLister
mclister at zeesource.net
Fri Jan 25 13:36:46 PST 2008
Hi All,
I am experiencing a strange performance issue.
We have a table of entries that contains latitude, longitude values
and I have a simple query to retrieve all entries within a specified 2-
D box.
The latitude, longitude are stored as decimals, plus a trigger
stores the corresponding geometry object.
When I do an EXPLAIN ANALYZE on one query that returns 3261 rows, it
executes in a reasonable 159ms:
EXPLAIN ANALYZE SELECT DISTINCT latitude, longitude, color FROM
NewEntries
WHERE groupid = 57925 AND
location @ SetSRID(MakeBox2D(SetSRID(MakePoint(-123.75,
36.597889), 4326),
SetSRID(MakePoint(-118.125,
40.979898), 4326)), 4326);
Unique (cost=23.73..23.74 rows=1 width=30) (actual
time=143.648..156.081 rows=3261 loops=1)
-> Sort (cost=23.73..23.73 rows=1 width=30) (actual
time=143.640..146.214 rows=3369 loops=1)
Sort Key: latitude, longitude, color
-> Index Scan using group_index on newentries
(cost=0.00..23.72 rows=1 width=30) (actual time=0.184..109.346
rows=3369 loops=1)
Index Cond: (groupid = 57925)
Filter: ("location" @
'0103000020E610000001000000050000000000000000F05EC0000000A0874C42400000000000F05EC0000000406D7D44400000000000885DC0000000406D7D44400000000000885DC0000000A0874C42400000000000F05EC0000000A0874C4240
'::geometry)
Total runtime: 159.430 ms
(7 rows)
If I issue the same query over JDBC or use a PSQL stored procedure,
it takes over 3000 ms, which, of course is unacceptable!
Function Scan on gettilelocations (cost=0.00..12.50 rows=1000
width=30) (actual time=3311.368..3319.265 rows=3261 loops=1)
Total runtime: 3322.529 ms
(2 rows)
The function gettilelocations is defined as:
CREATE OR REPLACE FUNCTION GetTileLocations(Integer, real, real, real,
real)
RETURNS SETOF TileLocation
AS
DECLARE
R TileLocation;
BEGIN
FOR R IN SELECT DISTINCT latitude, longitude, color FROM
NewEntries
WHERE groupid = $1 AND
location @ SetSRID(MakeBox2D(SetSRID(MakePoint($2,
$3), 4326),
SetSRID(MakePoint($4, $5), 4326)),
4326) LOOP
RETURN NEXT R;
END LOOP;
RETURN;
END;
LANGUAGE plpgsql STABLE RETURNS NULL ON NULL INPUT;
Can someone please tell me what we are doing wrong? Any help would
be greatly appreciated.
Thanks
Claire
Claire McLister mclister at zeesource.net
21060 Homestead Road Suite 150
Cupertino, CA 95014 408-733-2737(fax)
http://www.zeemaps.com
