[postgis-users] PostGIS Contains / Intersects / Within Performance
Paul Ramsey
pramsey at refractions.net
Mon Jan 28 11:28:43 PST 2008
Bruce,
You need the trunk of both postgis and geos to test the new
performance goodies..
P
On Jan 28, 2008, at 11:24 AM, Bruce Rindahl wrote:
> Thanks Paul
> I am not sure this is the place for these comments but...
> I upgraded MinGW to version 5.1.3 and that fixed the crash on
> Geos-3.0.0 but
> I am getting compile errors on the SVN snapshot given in the link
> below.
> Can I test the performance upgrades using the 3.0.0 version or do I
> need to
> get the SVN version working?
> Bruce
> -----Original Message-----
> From: Paul Ramsey [mailto:pramsey at refractions.net]
> Sent: Monday, January 28, 2008 11:37 AM
> To: rindahl at lrcwe.com; PostGIS Users Discussion
> Cc: 'Ben Jubb'
> Subject: Re: [postgis-users] PostGIS Contains / Intersects / Within
> Performance
> fixed
> http://geos.refractions.net/downloads/geos-svn.tar.bz2
> On Jan 28, 2008, at 10:22 AM, Bruce Rindahl wrote:
>> I am getting a major crash on ld.exe when trying to compile 3.0.0.
>> I can't
>> seem to get a complete SVN snapshot when using the directions on
>> http://geos.refractions.net (configure is missing).
>> The link for geos-svn.tar.bz2
> (http://geos.refractions.net/geos-svn.tar.bz2
>> gives me a 404 error.
>> Could you check on the hourly snapshot link?
>> Thanks
>> Bruce
>> From: Ben Jubb [mailto:benjubb at refractions.net]
>> Sent: Monday, January 28, 2008 9:55 AM
>> Performance
>> I had no trouble compiling GEOS SVN on MinGW.
>> b
>> Ok let me try this differently :)
>> Has anyone had any luck compiling GOES 3.0 or GEOS SVN under MingW?
>> It is
>> causing major crashes for me. If not then I will file a bug.
>> Thanks
>> Bruce
>> Sent: Saturday, January 26, 2008 9:54 AM
>> Performance
>> I don't know, try and tell us! :)
>> P
>> On Jan 25, 2008, at 7:58 PM, Bruce Rindahl wrote:
>> Does the SVN of GEOS compile under MingW??
>> Bruce
>> From: postgis-users-bounces at postgis.refractions.net
>> [mailto:postgis-users-bounces at postgis.refractions.net] On
>> Behalf Of
>> Paul
>> Ramsey
>> Sent: Friday, January 25, 2008 11:46 AM
>> To: PostGIS Users Discussion
>> Subject: [postgis-users] PostGIS Contains / Intersects /
>> Within
>> Performance
>> I'd love to see some people here with large data volumes who
>> do
>> contains/intersects/within tests do some testing of the new
>> postgis/
>> geos prepared geometry code...
>> To test the new functions
>> - install the svn snapshot of GEOS
>> - install the svn snapshot of PostGIS
>> - use the ST_ContainsPrepared(g1,g2) predicate for the
>> testing
>> We've seen performance improvements of between 5 and 100
>> times
>> faster. The bigger and more complicated your test
>> geometries are,
>> the faster it should be.
>> Thanks,
>> P.
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
