[postgis-users] PostGIS Contains / Intersects / Within Performance
Bruce Rindahl
rindahl at lrcwe.com
Mon Jan 28 11:24:35 PST 2008
Thanks Paul
I am not sure this is the place for these comments but...
I upgraded MinGW to version 5.1.3 and that fixed the crash on Geos-3.0.0 but
I am getting compile errors on the SVN snapshot given in the link below.
Can I test the performance upgrades using the 3.0.0 version or do I need to
get the SVN version working?
Bruce
-----Original Message-----
From: Paul Ramsey [mailto:pramsey at refractions.net]
Sent: Monday, January 28, 2008 11:37 AM
To: rindahl at lrcwe.com; PostGIS Users Discussion
Cc: 'Ben Jubb'
Subject: Re: [postgis-users] PostGIS Contains / Intersects / Within
Performance
fixed
http://geos.refractions.net/downloads/geos-svn.tar.bz2
On Jan 28, 2008, at 10:22 AM, Bruce Rindahl wrote:
> I am getting a major crash on ld.exe when trying to compile 3.0.0.
> I can't
> seem to get a complete SVN snapshot when using the directions on
> http://geos.refractions.net (configure is missing).
> The link for geos-svn.tar.bz2
(http://geos.refractions.net/geos-svn.tar.bz2
> gives me a 404 error.
> Could you check on the hourly snapshot link?
> Thanks
> Bruce
> From: Ben Jubb [mailto:benjubb at refractions.net]
> Sent: Monday, January 28, 2008 9:55 AM
> Performance
> I had no trouble compiling GEOS SVN on MinGW.
> b
> Ok let me try this differently :)
> Has anyone had any luck compiling GOES 3.0 or GEOS SVN under MingW?
> It is
> causing major crashes for me. If not then I will file a bug.
> Thanks
> Bruce
> Sent: Saturday, January 26, 2008 9:54 AM
> Performance
> I don't know, try and tell us! :)
> P
> On Jan 25, 2008, at 7:58 PM, Bruce Rindahl wrote:
> Does the SVN of GEOS compile under MingW??
> Bruce
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of
> Paul
> Ramsey
> Sent: Friday, January 25, 2008 11:46 AM
> To: PostGIS Users Discussion
> Subject: [postgis-users] PostGIS Contains / Intersects /
> Within
> Performance
> I'd love to see some people here with large data volumes who
> do
> contains/intersects/within tests do some testing of the new
> postgis/
> geos prepared geometry code...
> To test the new functions
> - install the svn snapshot of GEOS
> - install the svn snapshot of PostGIS
> - use the ST_ContainsPrepared(g1,g2) predicate for the
> testing
> We've seen performance improvements of between 5 and 100
> times
> faster. The bigger and more complicated your test
> geometries are,
> the faster it should be.
> Thanks,
> P.
> postgis-users mailing list
