[postgis-users] PostGIS Contains / Intersects / Within Performance
Bruce Rindahl
rindahl at lrcwe.com
Mon Jan 28 07:12:40 PST 2008
Ok let me try this differently :)
Has anyone had any luck compiling GOES 3.0 or GEOS SVN under MingW? It is
causing major crashes for me. If not then I will file a bug.
Thanks
Bruce
-----Original Message-----
From: Paul Ramsey [mailto:pramsey at refractions.net]
Sent: Saturday, January 26, 2008 9:54 AM
To: rindahl at lrcwe.com; PostGIS Users Discussion
Subject: Re: [postgis-users] PostGIS Contains / Intersects / Within
Performance
I don't know, try and tell us! :)
P
On Jan 25, 2008, at 7:58 PM, Bruce Rindahl wrote:
> Does the SVN of GEOS compile under MingW??
> Bruce
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> Paul
> Ramsey
> Sent: Friday, January 25, 2008 11:46 AM
> To: PostGIS Users Discussion
> Subject: [postgis-users] PostGIS Contains / Intersects / Within
> Performance
> I'd love to see some people here with large data volumes who do
> contains/intersects/within tests do some testing of the new postgis/
> geos prepared geometry code...
> To test the new functions
> - install the svn snapshot of GEOS
> - install the svn snapshot of PostGIS
> - use the ST_ContainsPrepared(g1,g2) predicate for the testing
> We've seen performance improvements of between 5 and 100 times
> faster. The bigger and more complicated your test geometries are,
> the faster it should be.
> Thanks,
> P.
> postgis-users mailing list
