[postgis-users] PostGIS Contains / Intersects / Within Performance
Ben Jubb
benjubb at refractions.net
Mon Jan 28 08:55:02 PST 2008
I had no trouble compiling GEOS SVN on MinGW.
b
Bruce Rindahl wrote:
> Ok let me try this differently :)
> Has anyone had any luck compiling GOES 3.0 or GEOS SVN under MingW? It is
> causing major crashes for me. If not then I will file a bug.
> Thanks
> Bruce
> -----Original Message-----
> From: Paul Ramsey [mailto:pramsey at refractions.net]
> Sent: Saturday, January 26, 2008 9:54 AM
> To: rindahl at lrcwe.com; PostGIS Users Discussion
> Subject: Re: [postgis-users] PostGIS Contains / Intersects / Within
> Performance
> I don't know, try and tell us! :)
> P
> On Jan 25, 2008, at 7:58 PM, Bruce Rindahl wrote:
>> Does the SVN of GEOS compile under MingW??
>> Bruce
>> From: postgis-users-bounces at postgis.refractions.net
>> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
>> Paul
>> Ramsey
>> Sent: Friday, January 25, 2008 11:46 AM
>> To: PostGIS Users Discussion
>> Subject: [postgis-users] PostGIS Contains / Intersects / Within
>> Performance
>> I'd love to see some people here with large data volumes who do
>> contains/intersects/within tests do some testing of the new postgis/
>> geos prepared geometry code...
>> To test the new functions
>> - install the svn snapshot of GEOS
>> - install the svn snapshot of PostGIS
>> - use the ST_ContainsPrepared(g1,g2) predicate for the testing
>> We've seen performance improvements of between 5 and 100 times
>> faster. The bigger and more complicated your test geometries are,
>> the faster it should be.
>> Thanks,
>> P.
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080128/dd3b3d17/attachment.html>
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080128/dd3b3d17/attachment.vcf>
