Thanks again Paul, >> GEOS does not support 3D operations ? > > No, except for the exception above. So, is it possible to use a C/C++ interface ? For instance, CGAL provides high level geometric computation. Then, can one use a C++ programming language to perform this kind of tasks in a PostGIS context ? Regards, Olivier
