[postgis-users] 3D support in PostGIS
Ben Jubb
benjubb at refractions.net
Mon Jan 28 09:07:13 PST 2008
1. yes
2. indexes are 2D only, Z is ignored.
3. your example would be true. Z is ignored.
Olivier Tournaire wrote:
> Hi all,
> I a currently studying 3D GIS and I have a few questions about
> PostGIS. I can find any recent or full answer on the web, so, I try
> the mailing list.
> 1. As far as I know, PostGIS is ale to store 3D data. Am I right ?
> 2. If I create a spatial index on a table which contains 3D
> geometries, is it a real 3D index, or the objects are projected onto
> the ground and the the index is built with this projection ?
> 3. Last, but not least, is it possible to have operations on
> geometries in a 3D framework. For example, it I test if the point
> (0,0,50) is within the polygon ( (-10,-10,0) (-10,10,0) (10,10,0)
> (10,-10,0) ), what is the answer ? In other words, is the result
> obtained with taking into account the Z coordinate or not ?
> Best regards,
> Olivier
> postgis-users mailing list
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080128/426fdf2c/attachment.vcf>
