[postgis-users] Problems while loading lwpostgis.sql... Pleaseprovide your inputs / help
Tim Bowden
tim.bowden at westnet.com.au
Wed Jan 30 05:56:41 PST 2008
On Wed, 2008-01-30 at 19:05 +0530, ahmadbasha.shaik at wipro.com wrote:
> Yes andy
> a) /usr/local/lib was already present in /etc/ld.so.conf
> b) ldconfig was also performed
If you've used the default source install of postgresql, you'll
need /usr/local/pgsql/lib
HTH,
Tim Bowden
> Can you please let me know what else might be the problem as I am
> in a urgency to load GIS data in PostgreSQL (with Post GIS).
> Regards
> Ahmad
> ______________________________________________________________________
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> Andy Dale
> Sent: Wednesday, January 30, 2008 6:53 PM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] Problems while loading lwpostgis.sql...
> Hi,
> Have you added /usr/local/lib to /etc/ld.so.conf and then performed a
> ldconfig ?
> Cheers,
> Andy
> On 30/01/2008, ahmadbasha.shaik at wipro.com <ahmadbasha.shaik at wipro.com>
> wrote:
> Hi
> I am facing problems while loading lwpostgis.sql in PostGIS.
> Below is a detailed explanation.
> psql -d test -f /usr/share/lwpostgis.sql
> ERROR: could not access file "$libdir/liblwgeom.so.1.2": No
> such file or directory
> ERROR: current transaction is aborted, commands ignored until
> end of transaction block
> Hence , I tried creating a simple test.sql which has the
> create replace functions for histogram. I have detailed the
> environmnent that we are
> using, the statement of lwpostgis.sql we executed and the
> error encountered
> Environment:
> Operationg System : Red Hat Linux 3.4.5-2
> Database : PostgreSQL 8.2.6
> Extensions : geos-3.0.0, proj-4.6.0, postgis-1.2.1
> test.sql (three sql commands that I have taken from
> lwpostgis.sql to check)
> BEGIN;
> CREATE OR REPLACE FUNCTION histogram2d_in(cstring)
> RETURNS histogram2d
> AS '$libdir/liblwgeom.so.1.2', 'lwhistogram2d_in'
> LANGUAGE 'C' IMMUTABLE STRICT; -- WITH (isstrict);
> CREATE OR REPLACE FUNCTION histogram2d_out(histogram2d)
> RETURNS cstring
> AS '$libdir/liblwgeom.so.1.2', 'lwhistogram2d_out'
> CREATE TYPE histogram2d (
> alignment = double,
> internallength = variable,
> input = histogram2d_in,
> output = histogram2d_out,
> storage = main
> COMMIT;
> ERROR Encountered
> BEGIN
> psql:test.sql:6: NOTICE: type "histogram2d" is not yet
> defined
> DETAIL: Creating a shell type definition.
> psql:test.sql:6: ERROR: could not access file
> "$libdir/liblwgeom.so.1.2": No such file or directory
> psql:test.sql:11: ERROR: current transaction is aborted,
> commands ignored until end of transaction block
> psql:test.sql:19: ERROR: current transaction is aborted,
> ROLLBACK
> Varions Options we tried:
> a) Changed the permissions $libdir i.e. /usr/lib/pgsl to 777
> b) Hardcoded the path /usr/lib/pgsql in this test.sql
> c) We also tried hardcoding the path /usr/lib/pgsql instead of
> $libdir in lwpostgis.sql when we tried loading functions and
> types in lwpostgis.sql
> Can somebody please guide us or give directions what can be
> done.
> Regards
> Ahmad
> P Please do not print this email unless it is absolutely
> necessary. Spread environmental awareness.
> The information contained in this electronic message and any
> attachments to this message are intended for the exclusive use
> of the addressee(s) and may contain proprietary, confidential
> or privileged information. If you are not the intended
> recipient, you should not disseminate, distribute or copy this
> e-mail. Please notify the sender immediately and destroy all
> copies of this message and any attachments.
> WARNING: Computer viruses can be transmitted via email. The
> recipient should check this email and any attachments for the
> presence of viruses. The company accepts no liability for any
> damage caused by any virus transmitted by this email.
> www.wipro.com
> postgis-users mailing list
> P Please do not print this email unless it is absolutely necessary.
> attachments to this message are intended for the exclusive use of the
> addressee(s) and may contain proprietary, confidential or privileged
> information. If you are not the intended recipient, you should not
> disseminate, distribute or copy this e-mail. Please notify the sender
> immediately and destroy all copies of this message and any
> attachments.
> WARNING: Computer viruses can be transmitted via email. The recipient
> should check this email and any attachments for the presence of
> viruses. The company accepts no liability for any damage caused by any
> www.wipro.com
