[postgis-users] Problems while loading lwpostgis.sql...Pleaseprovide your inputs / help
ahmadbasha.shaik at wipro.com
Wed Jan 30 06:22:06 PST 2008
Hey Tim
That entry also is there in /etc/ld.so.conf file. Please let me
know if there is any other way out.
Regards
Ahmad
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Tim
Bowden
Sent: Wednesday, January 30, 2008 7:27 PM
To: PostGIS Users Discussion
Subject: RE: [postgis-users] Problems while loading
On Wed, 2008-01-30 at 19:05 +0530, ahmadbasha.shaik at wipro.com wrote:
> Yes andy
> a) /usr/local/lib was already present in /etc/ld.so.conf
> b) ldconfig was also performed
If you've used the default source install of postgresql, you'll need
/usr/local/pgsql/lib
HTH,
Tim Bowden
> Can you please let me know what else might be the problem as I am
> in a urgency to load GIS data in PostgreSQL (with Post GIS).
> Regards
> Ahmad
> ______________________________________________________________________
> Andy Dale
> Sent: Wednesday, January 30, 2008 6:53 PM
> Subject: Re: [postgis-users] Problems while loading lwpostgis.sql...
> Hi,
> Have you added /usr/local/lib to /etc/ld.so.conf and then performed a
> ldconfig ?
> Cheers,
> Andy
> On 30/01/2008, ahmadbasha.shaik at wipro.com <ahmadbasha.shaik at wipro.com>
> wrote:
> Hi
> I am facing problems while loading lwpostgis.sql in PostGIS.
> Below is a detailed explanation.
> psql -d test -f /usr/share/lwpostgis.sql
> ERROR: could not access file "$libdir/liblwgeom.so.1.2": No
> such file or directory
> ERROR: current transaction is aborted, commands ignored until
> end of transaction block
> Hence , I tried creating a simple test.sql which has the
> create replace functions for histogram. I have detailed the
> environmnent that we are
> using, the statement of lwpostgis.sql we executed and the
> error encountered
> Environment:
> Operationg System : Red Hat Linux 3.4.5-2
> Database : PostgreSQL 8.2.6
> Extensions : geos-3.0.0, proj-4.6.0, postgis-1.2.1
> test.sql (three sql commands that I have taken from
> lwpostgis.sql to check)
> BEGIN;
> CREATE OR REPLACE FUNCTION histogram2d_in(cstring)
> RETURNS histogram2d
> AS '$libdir/liblwgeom.so.1.2', 'lwhistogram2d_in'
> LANGUAGE 'C' IMMUTABLE STRICT; -- WITH (isstrict);
> CREATE OR REPLACE FUNCTION histogram2d_out(histogram2d)
> RETURNS cstring
> AS '$libdir/liblwgeom.so.1.2', 'lwhistogram2d_out'
> CREATE TYPE histogram2d (
> alignment = double,
> internallength = variable,
> input = histogram2d_in,
> output = histogram2d_out,
> storage = main
> COMMIT;
> ERROR Encountered
> BEGIN
> psql:test.sql:6: NOTICE: type "histogram2d" is not yet
> defined
> DETAIL: Creating a shell type definition.
> psql:test.sql:6: ERROR: could not access file
> "$libdir/liblwgeom.so.1.2": No such file or directory
> psql:test.sql:11: ERROR: current transaction is aborted,
> commands ignored until end of transaction block
> psql:test.sql:19: ERROR: current transaction is aborted,
> ROLLBACK
> Varions Options we tried:
> a) Changed the permissions $libdir i.e. /usr/lib/pgsl to 777
> b) Hardcoded the path /usr/lib/pgsql in this test.sql
> c) We also tried hardcoding the path /usr/lib/pgsql instead of
> $libdir in lwpostgis.sql when we tried loading functions and
> types in lwpostgis.sql
> Can somebody please guide us or give directions what can be
> done.
> Regards
> Ahmad
> P Please do not print this email unless it is absolutely
> necessary. Spread environmental awareness.
> The information contained in this electronic message and any
> attachments to this message are intended for the exclusive use
> of the addressee(s) and may contain proprietary, confidential
> or privileged information. If you are not the intended
> recipient, you should not disseminate, distribute or copy this
> e-mail. Please notify the sender immediately and destroy all
> copies of this message and any attachments.
> WARNING: Computer viruses can be transmitted via email. The
> recipient should check this email and any attachments for the
> presence of viruses. The company accepts no liability for any
> damage caused by any virus transmitted by this email.
> www.wipro.com
> postgis-users mailing list
> P Please do not print this email unless it is absolutely necessary.
> attachments to this message are intended for the exclusive use of the
> addressee(s) and may contain proprietary, confidential or privileged
> information. If you are not the intended recipient, you should not
> disseminate, distribute or copy this e-mail. Please notify the sender
> immediately and destroy all copies of this message and any
> attachments.
> WARNING: Computer viruses can be transmitted via email. The recipient
> should check this email and any attachments for the presence of
> viruses. The company accepts no liability for any damage caused by any
> www.wipro.com
Please do not print this email unless it is absolutely necessary. Spread environmental awareness.
The information contained in this electronic message and any attachments to this message are intended for the exclusive use of the addressee(s) and may contain proprietary, confidential or privileged information. If you are not the intended recipient, you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately and destroy all copies of this message and any attachments.
WARNING: Computer viruses can be transmitted via email. The recipient should check this email and any attachments for the presence of viruses. The company accepts no liability for any damage caused by any virus transmitted by this email.
www.wipro.com
