[postgis-users] Problems while loadinglwpostgis.sql...Pleaseprovide your inputs / help
Paul Ramsey pramsey at refractions.net
Wed Jan 30 20:20:21 PST 2008
Sorry, it's a black box from here. Your description of what you've
tried below does not leave me with any obvious solutions I can
ascertain without working on the box directly.  You have tried all the
obvious things, which only leaves the non-obvious things.
P
On Jan 30, 2008, at 7:59 PM, <ahmadbasha.shaik at wipro.com> <ahmadbasha.shaik at wipro.com
 > wrote:
> Hey Paul
> 	Please give me your inputs as to what could be the problem with
> regards to the environment.
> Yes this liblwgeom.so.1.2 file actually exists. Following is the ls -
> ltr
> listing of /usr/lib/pgsql
> lrwxrwxrwx  1 root root      16 Jan 30 16:24 liblwgeom.so ->
> liblwgeom.so.1.2
> lrwxrwxrwx  1 root root      16 Jan 30 16:24 liblwgeom.so.1 ->
> liblwgeom.so.1.2
> -rwxrwxrwx  1 root root  894867 Jan 30 16:24 liblwgeom.so.1.2
> Please provide your inputs.
> Regards
> Ahmad
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
> Paul
> Ramsey
> Sent: Wednesday, January 30, 2008 9:59 PM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] Problems while
> This is certainly an environment problem, not a software problem...
> You have confirmed that liblwgeom.so.1.2 actually exists?
> On Jan 30, 2008, at 6:22 AM, <ahmadbasha.shaik at wipro.com>
> <ahmadbasha.shaik at wipro.com  > wrote:
>> Hey Tim
>> 	That entry also is there in /etc/ld.so.conf file. Please let me
> know
>> if there is any other way out.
>> Regards
>> Ahmad
>> Tim Bowden
>> Sent: Wednesday, January 30, 2008 7:27 PM
>> Subject: RE: [postgis-users] Problems while loading
>> On Wed, 2008-01-30 at 19:05 +0530, ahmadbasha.shaik at wipro.com wrote:
>>> Yes andy
>>>   a) /usr/local/lib was already present in /etc/ld.so.conf
>>>   b) ldconfig was also performed
>> If you've used the default source install of postgresql, you'll need
>> /usr/local/pgsql/lib
>> HTH,
>> Tim Bowden
>>>   Can you please let me know what else might be the problem as I am
>>> in a urgency to load GIS data in PostgreSQL (with Post GIS).
>>> Regards
>>> Ahmad
> ______________________________________________________________________
>>> Andy Dale
>>> Sent: Wednesday, January 30, 2008 6:53 PM
>>> Subject: Re: [postgis-users] Problems while loading lwpostgis.sql...
>>> Hi,
>>> Have you added /usr/local/lib to /etc/ld.so.conf and then
>>> performed a
>>> ldconfig ?
>>> Cheers,
>>> Andy
>>> On 30/01/2008, ahmadbasha.shaik at wipro.com
>>> wrote:
>>>       Hi
>>>       I am facing problems while loading lwpostgis.sql in PostGIS.
>>>       Below is a detailed explanation.
>>>       psql -d test -f /usr/share/lwpostgis.sql
>>>       ERROR:  could not access file "$libdir/liblwgeom.so.1.2": No
>>>       such file or directory
>>>       ERROR:  current transaction is aborted, commands ignored until
>>>       end of transaction block
>>>       Hence , I tried creating a simple test.sql which has the
>>>       create replace functions for histogram. I have detailed the
>>>       environmnent that we are
>>>       using, the statement of lwpostgis.sql we executed and the
>>>       error encountered
>>>       Environment:
>>>       Operationg System : Red Hat Linux 3.4.5-2
>>>       Database : PostgreSQL 8.2.6
>>>       Extensions : geos-3.0.0, proj-4.6.0, postgis-1.2.1
>>>       test.sql (three sql commands that I have taken from
>>>       lwpostgis.sql to check)
>>>       BEGIN;
>>>       CREATE OR REPLACE FUNCTION histogram2d_in(cstring)
>>>               RETURNS histogram2d
>>>               AS '$libdir/liblwgeom.so.1.2', 'lwhistogram2d_in'
>>>               LANGUAGE 'C' IMMUTABLE STRICT; -- WITH (isstrict);
>>>       CREATE OR REPLACE FUNCTION histogram2d_out(histogram2d)
>>>               RETURNS cstring
>>>               AS '$libdir/liblwgeom.so.1.2', 'lwhistogram2d_out'
>>>       CREATE TYPE histogram2d (
>>>               alignment = double,
>>>               internallength = variable,
>>>               input = histogram2d_in,
>>>               output = histogram2d_out,
>>>               storage = main
>>>       COMMIT;
>>>       ERROR Encountered
>>>       BEGIN
>>>       psql:test.sql:6: NOTICE:  type "histogram2d" is not yet
>>>       defined
>>>       DETAIL:  Creating a shell type definition.
>>>       psql:test.sql:6: ERROR:  could not access file
>>>       "$libdir/liblwgeom.so.1.2": No such file or directory
>>>       psql:test.sql:11: ERROR:  current transaction is aborted,
>>>       commands ignored until end of transaction block
>>>       psql:test.sql:19: ERROR:  current transaction is aborted,
>>>       ROLLBACK
>>>       Varions Options we tried:
>>>       a) Changed the permissions $libdir i.e. /usr/lib/pgsl to 777
>>>       b) Hardcoded the path /usr/lib/pgsql in this test.sql
>>>       c) We also tried hardcoding the path /usr/lib/pgsql instead of
>>>       $libdir in lwpostgis.sql when we tried loading functions and
>>>       types in lwpostgis.sql
>>>       Can somebody please guide us or give directions what can be
>>>       done.
>>>       Regards
>>>       Ahmad
>>>       P Please do not print this email unless it is absolutely
>>>       necessary. Spread environmental awareness.
>>>       The information contained in this electronic message and any
>>>       attachments to this message are intended for the exclusive use
>>>       of the addressee(s) and may contain proprietary, confidential
>>>       or privileged information. If you are not the intended
>>>       recipient, you should not disseminate, distribute or copy this
>>>       e-mail. Please notify the sender immediately and destroy all
>>>       copies of this message and any attachments.
>>>       WARNING: Computer viruses can be transmitted via email. The
>>>       recipient should check this email and any attachments for the
>>>       presence of viruses. The company accepts no liability for any
>>>       damage caused by any virus transmitted by this email.
>>>       www.wipro.com
>>>       postgis-users mailing list
>>>       postgis-users at postgis.refractions.net
>>>       http://postgis.refractions.net/mailman/listinfo/postgis-users
>>> P Please do not print this email unless it is absolutely necessary.
>>> attachments to this message are intended for the exclusive use of
>>> the
>>> addressee(s) and may contain proprietary, confidential or privileged
>>> information. If you are not the intended recipient, you should not
>>> disseminate, distribute or copy this e-mail. Please notify the
>>> sender
>>> immediately and destroy all copies of this message and any
>>> attachments.
>>> recipient
>>> should check this email and any attachments for the presence of
>>> viruses. The company accepts no liability for any damage caused by
>>> any
>>> www.wipro.com
>> the addressee(s) and may contain proprietary, confidential or
>> privileged information. If you are not the intended recipient, you
>> should not disseminate, distribute or copy this e-mail. Please
>> notify the sender immediately and destroy all copies of this message
>> presence of viruses. The company accepts no liability for any damage
>> www.wipro.com
> www.wipro.com
