[Fwd: RE: [postgis-users] Problems while loading lwpostgis.sql...Pleaseprovide your inputs / help]
Tim Bowden tim.bowden at westnet.com.au
Wed Jan 30 22:58:45 PST 2008
Resending because it looks like the original got mangled by Paul's use
of sorbs.net to filter the mailing list...
-------- Forwarded Message --------
To: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
Subject: RE: [postgis-users] Problems while loading
Date: Thu, 31 Jan 2008 13:19:33 +0900
On Wed, 2008-01-30 at 19:52 +0530, ahmadbasha.shaik at wipro.com wrote:
> Hey Tim
> 	That entry also is there in /etc/ld.so.conf file. Please let me
> know if there is any other way out.
> Regards
> Ahmad
can you post the output of two commands:
cat /etc/ld.so.conf
ldd /usr/local/pgsql/lib/liblwgeom.so
Could you also clarify what version of red hat linux you are using.
Tim
