[Fwd: RE: [postgis-users] Problems while loadinglwpostgis.sql...Pleaseprovide your inputs / help]
Tim Bowden tim.bowden at westnet.com.au
Wed Jan 30 22:59:26 PST 2008
resending...
-------- Forwarded Message --------
To: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
Subject: RE: [postgis-users] Problems while
Date: Thu, 31 Jan 2008 13:41:04 +0900
On Thu, 2008-01-31 at 09:29 +0530, ahmadbasha.shaik at wipro.com wrote:
> Hey Paul
> 	Please give me your inputs as to what could be the problem with
> regards to the environment.
> Yes this liblwgeom.so.1.2 file actually exists. Following is the ls -ltr
> listing of /usr/lib/pgsql
> lrwxrwxrwx  1 root root      16 Jan 30 16:24 liblwgeom.so ->
> liblwgeom.so.1.2
> lrwxrwxrwx  1 root root      16 Jan 30 16:24 liblwgeom.so.1 ->
> liblwgeom.so.1.2
> -rwxrwxrwx  1 root root  894867 Jan 30 16:24 liblwgeom.so.1.2
You indirectly indicated earlier that you installed to /usr/local/pgsql
so why are these files in /usr/lib/pgsql?  How did you install
postrgresql and postgis?
Tim Bowden
> Please provide your inputs.
> Regards
> Ahmad
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Paul
> Ramsey
> Sent: Wednesday, January 30, 2008 9:59 PM
> Subject: Re: [postgis-users] Problems while
> This is certainly an environment problem, not a software problem...
> You have confirmed that liblwgeom.so.1.2 actually exists?
> On Jan 30, 2008, at 6:22 AM, <ahmadbasha.shaik at wipro.com>
> <ahmadbasha.shaik at wipro.com  > wrote:
> > Hey Tim
> > 	That entry also is there in /etc/ld.so.conf file. Please let me
> know
> > if there is any other way out.
> > Regards
> > Ahmad
> > Tim Bowden
> > Sent: Wednesday, January 30, 2008 7:27 PM
> > Subject: RE: [postgis-users] Problems while loading
> > On Wed, 2008-01-30 at 19:05 +0530, ahmadbasha.shaik at wipro.com wrote:
> >> Yes andy
> >>    a) /usr/local/lib was already present in /etc/ld.so.conf
> >>    b) ldconfig was also performed
> > If you've used the default source install of postgresql, you'll need
> > /usr/local/pgsql/lib
> > HTH,
> > Tim Bowden
> >>    Can you please let me know what else might be the problem as I am
> >> in a urgency to load GIS data in PostgreSQL (with Post GIS).
> >> Regards
> >> Ahmad
> ______________________________________________________________________
> >> Andy Dale
> >> Sent: Wednesday, January 30, 2008 6:53 PM
> >> Subject: Re: [postgis-users] Problems while loading lwpostgis.sql...
> >> Hi,
> >> Have you added /usr/local/lib to /etc/ld.so.conf and then performed a
> >> ldconfig ?
> >> Cheers,
> >> Andy
> >> On 30/01/2008, ahmadbasha.shaik at wipro.com
> >> wrote:
> >>        Hi
> >>        I am facing problems while loading lwpostgis.sql in PostGIS.
> >>        Below is a detailed explanation.
> >>        psql -d test -f /usr/share/lwpostgis.sql
> >>        ERROR:  could not access file "$libdir/liblwgeom.so.1.2": No
> >>        such file or directory
> >>        ERROR:  current transaction is aborted, commands ignored until
> >>        end of transaction block
> >>        Hence , I tried creating a simple test.sql which has the
> >>        create replace functions for histogram. I have detailed the
> >>        environmnent that we are
> >>        using, the statement of lwpostgis.sql we executed and the
> >>        error encountered
> >>        Environment:
> >>        Operationg System : Red Hat Linux 3.4.5-2
> >>        Database : PostgreSQL 8.2.6
> >>        Extensions : geos-3.0.0, proj-4.6.0, postgis-1.2.1
> >>        test.sql (three sql commands that I have taken from
> >>        lwpostgis.sql to check)
> >>        BEGIN;
> >>        CREATE OR REPLACE FUNCTION histogram2d_in(cstring)
> >>                RETURNS histogram2d
> >>                AS '$libdir/liblwgeom.so.1.2', 'lwhistogram2d_in'
> >>                LANGUAGE 'C' IMMUTABLE STRICT; -- WITH (isstrict);
> >>        CREATE OR REPLACE FUNCTION histogram2d_out(histogram2d)
> >>                RETURNS cstring
> >>                AS '$libdir/liblwgeom.so.1.2', 'lwhistogram2d_out'
> >>        CREATE TYPE histogram2d (
> >>                alignment = double,
> >>                internallength = variable,
> >>                input = histogram2d_in,
> >>                output = histogram2d_out,
> >>                storage = main
> >>        COMMIT;
> >>        ERROR Encountered
> >>        BEGIN
> >>        psql:test.sql:6: NOTICE:  type "histogram2d" is not yet
> >>        defined
> >>        DETAIL:  Creating a shell type definition.
> >>        psql:test.sql:6: ERROR:  could not access file
> >>        "$libdir/liblwgeom.so.1.2": No such file or directory
> >>        psql:test.sql:11: ERROR:  current transaction is aborted,
> >>        commands ignored until end of transaction block
> >>        psql:test.sql:19: ERROR:  current transaction is aborted,
> >>        ROLLBACK
> >>        Varions Options we tried:
> >>        a) Changed the permissions $libdir i.e. /usr/lib/pgsl to 777
> >>        b) Hardcoded the path /usr/lib/pgsql in this test.sql
> >>        c) We also tried hardcoding the path /usr/lib/pgsql instead of
> >>        $libdir in lwpostgis.sql when we tried loading functions and
> >>        types in lwpostgis.sql
> >>        Can somebody please guide us or give directions what can be
> >>        done.
> >>        Regards
> >>        Ahmad
> >>        P Please do not print this email unless it is absolutely
> >>        necessary. Spread environmental awareness.
> >>        The information contained in this electronic message and any
> >>        attachments to this message are intended for the exclusive use
> >>        of the addressee(s) and may contain proprietary, confidential
> >>        or privileged information. If you are not the intended
> >>        recipient, you should not disseminate, distribute or copy this
> >>        e-mail. Please notify the sender immediately and destroy all
> >>        copies of this message and any attachments.
> >>        WARNING: Computer viruses can be transmitted via email. The
> >>        recipient should check this email and any attachments for the
> >>        presence of viruses. The company accepts no liability for any
> >>        damage caused by any virus transmitted by this email.
> >>        www.wipro.com
> >>        postgis-users mailing list
> >>        http://postgis.refractions.net/mailman/listinfo/postgis-users
> >> P Please do not print this email unless it is absolutely necessary.
> >> attachments to this message are intended for the exclusive use of the
> >> addressee(s) and may contain proprietary, confidential or privileged
> >> information. If you are not the intended recipient, you should not
> >> disseminate, distribute or copy this e-mail. Please notify the sender
> >> immediately and destroy all copies of this message and any
> >> attachments.
> >> WARNING: Computer viruses can be transmitted via email. The recipient
> >> should check this email and any attachments for the presence of
> >> viruses. The company accepts no liability for any damage caused by
> >> any
> >> www.wipro.com
> > the addressee(s) and may contain proprietary, confidential or
> > privileged information. If you are not the intended recipient, you
> > should not disseminate, distribute or copy this e-mail. Please
> > notify the sender immediately and destroy all copies of this message
> > presence of viruses. The company accepts no liability for any damage
> > www.wipro.com
> Please do not print this email unless it is absolutely necessary. Spread environmental awareness.
> The information contained in this electronic message and any attachments to this message are intended for the exclusive use of the addressee(s) and may contain proprietary, confidential or privileged information. If you are not the intended recipient, you should not disseminate, distribute or copy this e-mail. Please notify the sender immediately and destroy all copies of this message and any attachments.
> WARNING: Computer viruses can be transmitted via email. The recipient should check this email and any attachments for the presence of viruses. The company accepts no liability for any damage caused by any virus transmitted by this email.
> www.wipro.com
