[postgis-users] about MS ACCESS y PostgreSQL
postgis.domain.thewild at spamgourmet.com
Tue Jul 1 07:10:31 PDT 2008
exportSQL v3.2 does a really good job at this (Access VBA Macro).
http://www.rot13.org/~dpavlin/projects/sql/exportSQL3.txt
If I recall correctly, it did not work out-of-the-box and I tuned it a
bit to suit my needs and to correct some things that had changed in
postgres ('DATETIME' -> 'TIMESTAMP', E'...' escape-strings...)
I think you should give it a try though !
Arnaud
