[postgis-users] Testing for empty feature
Kevin Neufeld
kneufeld at refractions.net
Fri Jul 4 08:32:13 PDT 2008
I believe that an empty multipolygon is converted into an empty
geometrycollection in JTS and hence PostGIS.
postgis=# SELECT ST_AsText('MULTIPOLYGON EMPTY'::geometry);
st_astext
GEOMETRYCOLLECTION EMPTY
(1 row)
postgis=# SELECT ST_IsEmpty('MULTIPOLYGON EMPTY'::geometry);
st_isempty
t
(1 row)
Alternatively, I suppose you could get the number of points in the geometry.
postgis=# SELECT ST_NPoints('MULTIPOLYGON EMPTY'::geometry);
st_npoints
0
(1 row)
Cheers,
Kevin
Sean Fulton wrote:
> How do I test for an empty feature such as 'MULTIPOLYGON(( EMPTY ))' ?
> IsEmpty seems to work only for collections.
> astext(wkb_geometry) = 'MULTIPOLYGON(( EMPTY ))' doesn't seem to work.
> Thanks,
> Sean
> postgis-users mailing list
