[postgis-users] I used ST_Buffer in hope of creating a polygon around my original polygon (rectangle), but I ended up with a circle with the center point right at the center of the polygon
Kevin Neufeld
kneufeld at refractions.net
Sun Jul 6 00:03:49 PDT 2008
googling1000 wrote:
> Hi,
> I'd appreciate it if someone can help me figure this out.
> I thought ST_Buffer will take in any geometry and make a "buffer" around
> that geometry.
Yes, it does.
> So, if you give it a rectangular polygon, you will get a bigger rectangular
> polygon.
Nope. You'll get a bigger rectangular polygon ... with rounded corners.
> But, I keep getting a circle, and it looks like postgis found the center of
> the polygon and made that point the center of the resulting circle.
If you've made your buffer large enough, it would indeed look like a
circle since all you'll see is the four rounded corners.
If you're after a larger rectangle, try simply expanding the bounding
box using ST_Expand(). Alternatively, you could try ST_Scale().
Cheers,
-- Kevin
