[postgis-users] Windows Crash
Chris Hermansen
chris.hermansen at timberline.ca
Sun Jul 13 10:47:12 PDT 2008
Regina, all;
I read the top four articles on this blog and I guess I just don't
understand why someone would waste their valuable (?) time writing such
pointless material, whether the topic be Windows or Linux or OS/X or
whatever.
Obe, Regina wrote:
> Slightly off topic. Has anyone seen this Linux Haters Blog. All
> Linux users should read it to understand how the mind of a windows
> user works so that we can interoperate.
> http://linuxhaters.blogspot.com/
> Similarly I would like to see a windows haters blog so I can form a
> fully unbiased opinion of the various factions. Is there such a thing?
> *From:* postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] *On Behalf Of
> *Bruce Rindahl
> *Sent:* Thursday, June 26, 2008 3:53 PM
> *To:* PostGIS Users Discussion
> *Subject:* Re: [postgis-users] Windows Crash
> Also on a long shot - do you have any hardware conflicts?
> Start->Control Panel->System->Hardware->Device Manager
> Are there any little yellow info symbols?
> Bruce
> Paul Ramsey wrote:
>> This is in no way a PostGIS problem, certainly nothing we can ever
>> fix, just something that the particular combination of PgAdmin, the
>> geometry we are feeding it, and the way the Windows rendering system
>> are interacting.
>> My experience has been that these days the thing that causes a modern
>> operating system (Windows, Linux, whatever) to crash is bad hardware,
>> usually bad memory, but sometimes other things. Basically, the
>> operating system itself is usually rock solid until you shake the
>> foundations it sits on, the hardware.
>> So basically, all I can offer is the doctor's advice to the patient
>> who said "doctor, doctor, it hurts when I raise my arm over my
>> head!"... "don't raise your arm over your head".
>> In the meantime, if you want to fiddle with things, swapping the order
>> of your memory in the sockets, changing out the video card, even
>> changing your screen resolution, might change the interaction such
>> that you can exercise this particular use case without dropping your
>> OS to the floor.
>> P.
>> On Thu, Jun 26, 2008 at 10:31 AM, Obe, Regina <robe.dnd at cityofboston.gov> wrote:
>>> I second Bruce's comment about unhelpful comments.
>>> It may actually have nothing to do with Windows in fact.
>>> Now getting back to the crash issue. Bob if you are still having the same
>>> issue with that file, maybe you can post that (or provide a link to the
>>> shape file you loaded). It could be something to do with the shapefile.
>>> I recall having this same issue with one particular geometry file way back
>>> in PgAdmin 1.6 and it was when I scrolled to a specific record it would
>>> crash, but then later additions (I either maybe never selected the geometry
>>> field again) or it was fixed in later versions. Doing an AsText
>>> always seemed to work where as displaying the raw binary was where I ran
>>> into issues.
>>> The other possibility is that it could be a defective graphics card. I
>>> forget which video cards I had bad runs with, but I remember having this
>>> same exact issue with my favorite programming editor JEdit. I had 2
>>> identical computers with same drivers etc and for some reason I would get
>>> intermittent crashes on one of them. I finally just got fed up and replaced
>>> the graphics card and then it worked fine.
>>> Just some thoughts.
>>> Thanks,
>>> Regina
>>> ________________________________
>>> The substance of this message, including any attachments, may be
>>> confidential, legally privileged and/or exempt from disclosure pursuant to
>>> Massachusetts law. It is intended solely for the addressee. If you received
>>> this in error, please contact the sender and delete the material from any
>>> computer.
>>> Help make the earth a greener place. If at all possible resist printing this
>>> email and join us in saving paper.
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> *The substance of this message, including any attachments, may be
> pursuant to Massachusetts law. It is intended solely for the
> addressee. If you received this in error, please contact the sender
> and delete the material from any computer. *
> * Help make the earth a greener place. If at all possible resist
> printing this email and join us in saving paper. *
Regards,
Chris Hermansen mailto:chris.hermansen at timberline.ca
tel+1.604.714.2878 · fax+1.604.733.0631 · mob+1.778.232.0644
Timberline Natural Resource Group · http://www.timberline.ca
401 · 958 West 8th Avenue · Vancouver BC · Canada · V5Z 1E5
